Sun, Jan 12, 4:53 PM CST
Subject: Skullcap for V4?
MadameX ( ) posted Tue, 26 July 2011 at 5:10 PM · edited Wed, 25 December 2024 at 1:41 PM
Is there such a thing, free or otherwise?
geep ( ) posted Tue, 26 July 2011 at 5:24 PM · edited Tue, 26 July 2011 at 5:30 PM
Attached Link: "Skull Cap " Tutorial - compliments of Dr Geep Studios
Ask and ye shall receive .... sort of. 😄
Why not just make one?:huh: ...... It's easy when you know how. :biggrin:
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
LaurieA ( ) posted Tue, 26 July 2011 at 5:27 PM
You could make one in the group editor? Just select the faces you want and then spawn a prop.
MadameX ( ) posted Tue, 26 July 2011 at 5:34 PM · edited Tue, 26 July 2011 at 5:35 PM
The problem with  V4, I've found, is that her neck comes up onto the back of her head, making it seperate from the head group. So, if I want hair below the occipital (sp?) bone, I have to use two seperate groups.
geep ( ) posted Tue, 26 July 2011 at 5:34 PM
Attached Link: "How To Grow Hair ..." - compliments of Dr Geep Studios
And  then .................... :lol:
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Tue, 26 July 2011 at 5:35 PM
Quote - The problem with  V4, I've found, is that her neck comes up onto the back of her head, making it seperate from the head group.
It's called .............................................. the spine. :lol:
(sorry, couldn't resist)
cheers,
dr geep ... :o]
edited 10/5/2019
MadameX ( ) posted Tue, 26 July 2011 at 5:51 PM
Thanks for the help, I've already ventured into the hair room, so do know my way around (a little, anyway).
LOL...shoulda seen that coming, Dr. Geep!
geep ( ) posted Tue, 26 July 2011 at 5:54 PM
Quote - Thanks for the help, I've already ventured into the hair room, so do know my way around (a little, anyway).
Yup, you shoulda, ha ha. :lol:
cheers, (anyway)
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
LaurieA ( ) posted Tue, 26 July 2011 at 6:01 PM · edited Tue, 26 July 2011 at 6:02 PM
This is a V4 skullcap I just made.....I chose the faces I wanted on each group - neck and head - spawned props of each one then exported both pieces out of Poser and then back in and Weld identical vertices checked in re-import.
PhilC ( ) posted Tue, 26 July 2011 at 6:08 PM
A word of caution. If you spawn a prop from the original V4 mesh my understanding is that it is a derived object and its redistribution is restricted by the original V4 user license. Again this is my understanding, for a definitive answer check with DAZ.
What you do for your own use on your own computer is entirely up to you.
The Hair Designer has a tool that will make skull caps for pretty much any figure with a head. The Hair Designer license enables you to redistribute the result.
Hope this helps.
LaurieA ( ) posted Tue, 26 July 2011 at 6:10 PM · edited Tue, 26 July 2011 at 6:21 PM
I should have stressed that you can only spawn a prop from the figure if it's for your own use ;). I figured it was tho since the OP was asking if there already WAS one ;).
Thanks PhilC
geep ( ) posted Tue, 26 July 2011 at 6:54 PM · edited Tue, 26 July 2011 at 6:55 PM
  Yup ...
If you viewed my "Skull Cap" tutorial, you should have seen this WARNING. 😄
It's one of those ... READ & HEED ... thingies. :biggrin:
cheers,
dr geep ... :o]
edited 10/5/2019
MadameX ( ) posted Tue, 26 July 2011 at 8:05 PM
Thanks all!
Yes, I did see the warning, Dr. Geep, and this would have been for my own use.
Can a skullcap be made in a modeling program? Or would that also fall under that warning?
@ LaurieA: How do I reimport two props at the same time? I've never tried that before
Sorry if I'm being a bit dense here..
MadameX ( ) posted Tue, 26 July 2011 at 8:07 PM
Thanks, Phil for the link to Hair Designer. I'm checking it out now... :)
LaurieA ( ) posted Wed, 27 July 2011 at 12:06 AM · edited Wed, 27 July 2011 at 12:07 AM
Quote - Thanks all!
What ya do is export just the two hair props together. Because you're saving to one file, it's now one prop ;).
NanetteTredoux ( ) posted Fri, 29 July 2011 at 2:59 PM
I use the hair designer mostly for making skullcaps on which I then grow dynamic hair. Not only is the skullcap licensed for redistribution, it has handy morphs to shape it. And the topography is easy to customise in a modeller, for instance if you want to change the hairline.
Poser 11 Pro, Windows 10
