Forum Moderators: Staff
MarketPlace Showcase F.A.Q (Last Updated: 2024 Oct 22 7:52 am)
Attached Link: Amphi2_Mars360
Since the website is gone, I have uploaded the missing file and free add-on MAT collections to my Renderosity FileLocker:3dCritter
Thanks for the files.
I downloaded and installed them.
They work but I have been disappointed by the marked degrading of the texture quality when loaded onto the backdrop, compared with loading the texture files directly as background images.
This looks about the same as painting a texture onto a one-sided square prop.
For some time I have wanted to change background images within the same pz3 file and the only way I have found of doing it was by painting them onto squares. The loss of image quality made this an unacceptable solution.
I thought your backdrop would solve this issue. Am I missing something or does your backdrop method suffer from the same problem?
Norm
Yes, that is the picture and it is a rendering with the image placed on backdrop. As I recall, it used the first light set that is included with the backdrop, with the position of the shadow casting light adjusted to match the photo.
So, I'm not sure why you are not getting similar results, perhaps the renderi settings are a problem . If you would like to send me an example with a simple pz3, I could take a look.
3dCritter
I have attached a pz3 file showing an arch pasted to the backdrop and also using the jpg file as a the background. I used the first light set in your package.
This is the first time I have tried attaching a file to a Renderosity message so good luck on getting it.
Looks like the the message was sent without the file. I may need some hand holding to get the file to you. I used, "Attach a File" but apparently left out a step. Any suggestions?
Attached Link: 3dCritter's Free Stuff Page
Two free downloads for the Amphi Backdrop 2. Each contains 5 images with MAT poses.Photos from Arches National Park region in southern Utah.
3dCritter
