Tue, Nov 19, 9:33 AM CST
Subject: Problem with PPro 2010 Python...
AtelierAriel ( ) posted Thu, 04 August 2011 at 5:42 PM · edited Tue, 19 November 2024 at 9:14 AM
Does anyone know why files won't load from external programs in PPro210? I was using P3dO and Windows Explorer to load files into Poser 8 with no problems, beside occasional crash from PddO. Now nothing happens. It's as if something is blocking any Python communication between programs.
All I can think is that there must be something different in PPro that is causing the problem.
Any help for this would be really appreciated...
nruddock ( ) posted Thu, 04 August 2011 at 6:51 PM
Quote - It's as if something is blocking any Python communication between programs.
More than likely it's whatever firewall you're using.
bagginsbill ( ) posted Thu, 04 August 2011 at 6:58 PM
Did you open the firewall for PPro 2010? It's not the same program as Poser 8. But it does the same thing.
Also, don't run both at the same time.
AtelierAriel ( ) posted Thu, 04 August 2011 at 9:43 PM
Yes to firewall, didn't help.
No, only run one at a time.
Dizzi ( ) posted Fri, 05 August 2011 at 5:25 AM
I'm not sure if P3DO does use sockets, last time I heard about it, it ran a Python script to load stuff, so there's nothing the firewall can block.
How are you loading the content? Drag & Drop into Poser? Or via Python scripts? Where are those located? They may need to be installed into Poser Pro 2010. If you're using Windows 7 and Vista with UAC turned on, it could also be that Poser Pro 2010 cannot run the Python scripts, because it cannot access them due to Permissions...
You need to give more information :-)
yarp ( ) posted Fri, 05 August 2011 at 12:08 PM
As for P3dO, it may be configured to use sockets or not. And sockets do not work with P8 or PP2010.
1st the PoserPython plugin must be installed (available with Poser plugins pack).
Then in Options dialog, Plugins tab make sure: "Use with Poser Remote Procedure Call daemon (Prpc)" is unchecked.
Shoud work like this and as Dizzi said with these settings there's no network, no firewall involved.
Yarp
www.senosoft.com
Yarp - author of P3DO Organizer for Poser
Dizzi ( ) posted Fri, 05 August 2011 at 12:27 PM
Just a sidenote: The socket module was broken when Poser 8 initially shipped but the SR fixed that. The socket module was needed for the PRPC script. But that's not needed anymore to load content into Poser 8 / Pro 2010 as one can use the same methods the Poser library uses to talk to Poser.
bagginsbill ( ) posted Fri, 05 August 2011 at 12:46 PM
Which are sockets. grin
AtelierAriel ( ) posted Fri, 05 August 2011 at 2:24 PM
Thank you yarp! That did it. Now P3dO is working perfectly.
The other was loading from Windows Explorer. Could have something to do with Win764bit.
I've configured a right-click in Explorer that is supposed to work (and did in XP) but is now just dead. I'll get it eventually but actually don't need it since P3DO works.
yarp ( ) posted Sat, 06 August 2011 at 12:10 AM
You're welcome.
Didn't knew the socket module had been restored thanks fo the tip.
