Attached Link: http://home.pb.net/~stevecox/uvmapper.htm
Quick grab the UVmapper tool at Steve Cox's site. http://home.pb.net/~stevecox/uvmapper.htm Convert the Rhino mesh into an obj and make a new UV map for your creation. Then save the map and obj file. You'll be all set.First off, you can export the Rhino creation in Poser as an Obj file. Next open the UVmapper tool and import the obj file (File/Load Model.) Then go to Edit/New UV map and select Planar. You will have some options that you will have to play with yourself to get the look you are after. You may just want to start with a Planar map aligned on the Z axis, don't split, and no gaps in the map. That way your wood texture will cover the flat surface. If you are feeling more creative you could make a Box map and get the edges mapped. Once you are finished, Save Model, and Save Texture Map. Open up a paint program and place your desired texture over the portions of the new map. Then go back to poser and import the obj file then add the new texture.
