Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 22 3:39 am)
I don't know, if there is I'd also like to know about it. One sigh of the extra faces, as you probably have noticed is Poser renders them black, not to be confused with the bad geometry which you can fix with UV Mapper. What I done is locate them in Poser (go into a wireframe view) with Max running and then delete 'em in Max.
Attached Link: http://www.gfxcentral.com/bobo/ipas/ddf/
It's a max plugin that should remove duplicate faces. http://www.gfxcentral.com/bobo/ipas/ddf/ I still wonder if there is an app out there the opposite of Twoface (it makes a duplicate set of inversed normal faces)that is an all in one tool for removing any duplicate faces.This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Sliced all the joints for a brand new figure mesh, afterwards I realized that in the process I duplicated the vertices and faces in several parts of the figure. Took care of the duplicate vertices, but I'm not sure how to get rid of all the extra faces. I managed to pull this off in Max 3. Is there a utility, or some aspect of Max, I've overlooked that can remove the extra faces?
