Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 09 6:38 am)
Quote - I read the title of this thread "Am I right in thinking", and was going to advise against it, as thinking usually gives me a head ache. :blink:
I don't know the answer to the rest of the question.
Normally I'd take your advice, because it hurts, but sometimes it's necessary :)
Fugazi (without the aid of a safety net)
https://www.facebook.com/Fugazi3D
John,
I think this is possible. There is a thread at RDNA about converting pants for Brad by Phantom3D which would be worth looking at.
I don't know if you 'have to' weld a mesh for Poser Pro 2012 to convert it to weight mapping. I guess that would destroy any morph targets. Going the opposite way it sounds like converting a dynamic outfit to weight mapped conforming would be very easy though. Run it through the cloth room as a single mesh, and then apply weight mapping.
Cheers
Ian
ps. Your Digital Tailor videos are excellent.
Quote - John,
Cheers
Ian
Hi Ian
I think 2012 can either use a grouped mesh or welded single mesh. I have not even thought of the implecations of a weight mapped mesh in the cloth room :) if there are any.
It just occurred to me that converting conformed clothing made with a single ungrouped mesh could have real advantages for the fans of the cloth room :)
John
PS too kind :) hope you are having fun with them :)
Quote - That Poser Pro 2012 can handle clothes with or without the traditional poly groups.
They can be done without, but there are several advantages to sticking with groups (restricting influence of tools, selecting body parts, hiding body parts) and really only one disadvantage (loading morph targets from outside).
Quote - If so this is marvelous news for Dynamic Cloth fans, as conforming clothes will come in one main piece (with seperate details), making the conversion process much easier :)
You could work around this right now by just welding the seams with tools inside Poser, e.g. import the OBJ and check "Weld Identical Vertices".
The folks over at RDNA forums are saying that it's correct, yes, weight-mapping can be done over a single-grouped mesh.
BUT I don't think everyone will make that always. And I doubt that this can hope to become standard anytime soon. I mean, a lot of people are still stuck at Poser4-compatible content.
Feel free to call me Ohki!
Quote - That Poser Pro 2012 can handle clothes with or without the traditional poly groups. If so this is marvelous news for Dynamic Cloth fans, as conforming clothes will come in one main piece (with seperate details), making the conversion process much easier :)
John
I've been trying to convert conforming cloth to dynamic: the primary obstacle I've run into is that by design a given area's vertices don't share a close-enough common space with another area's vertices to where you could "weld" the entire garment together easily, so taking it into the cloth room is an exercise in futility as you watch the thing fall apart. But I seem to be missing something, by your remarks.
Good point, there's two aspects to making a conforming garment into dynamic - the body part borders, and parts of the model that are just not intended for use as dynamic. The latter won't be affected by whether the model is grouped or not, but you can address those with features already in Cloth Room like constrained groups, or decoration groups.
John
