Mon, Jan 27, 11:48 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 27 9:18 am)
Subject: Poser 8 Question
Philywebrider ( ) posted Sat, 20 August 2011 at 9:35 PM · edited Mon, 27 January 2025 at 11:45 AM
How can I change this back to Default?
Poser 8, PC  Windows 7
Philywebrider ( ) posted Sat, 20 August 2011 at 9:39 PM
I tried Factory state.
I still get that one line strip for the library listings.
Please help!!!!
RedPhantom ( ) posted Sat, 20 August 2011 at 10:00 PM
Site Admin
try deleting your ui prefs. Sorry I don't know exactly where that is in win7. I only have xp. Maybe try a search for it.
geep ( ) posted Sat, 20 August 2011 at 10:48 PM
Click the Klingon Toothpick and then ... select your options. 😄
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Sat, 20 August 2011 at 10:57 PM
Oops, sorry .......... didn't look closely enough at your image. ...  :sad:
Try this ... and then set up the Library window the way you want. ... 👍
cheers,
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
Philywebrider ( ) posted Sat, 20 August 2011 at 11:19 PM
The right side of my screen looks like this
Philywebrider ( ) posted Sat, 20 August 2011 at 11:23 PM
the left side of the screen looks like this.
Philywebrider ( ) posted Sat, 20 August 2011 at 11:24 PM
note how the library's are just one line.
Philywebrider ( ) posted Sat, 20 August 2011 at 11:37 PM · edited Sat, 20 August 2011 at 11:39 PM
I want the Hierachy window smaller and the Library window back on the right side and multi lines, (as in your sample )  Dr Gleep.
geep ( ) posted Sun, 21 August 2011 at 3:09 AM
Hmmm ...
cheers,
dr geep ... :o]
edited 10/5/2019
geep ( ) posted Sun, 21 August 2011 at 3:12 AM · edited Sun, 21 August 2011 at 3:14 AM
Ok, let's try this ... *(as in my second post in this threa)* 😄
Find the little tiny rectangle (it's almost invisible because it's sooooo small) ... :blink:
Click on it ... Click on "Floating" ... :huh:
All fixed ......... Yes ??? 👍 ??????????
cheers,
dr geep ... :o]
edited 10/5/2019
Philywebrider ( ) posted Sun, 21 August 2011 at 3:36 AM
I lost my all my libraries
geep ( ) posted Sun, 21 August 2011 at 3:43 AM
cheers,
dr geep ... :o]
edited 10/5/2019
millighost ( ) posted Sun, 21 August 2011 at 5:50 AM
Quote - I lost my all my libraries
Sometimes when reordering your UI some windows disappear for good. Easiest as Redphantom mentioned, is to remove the UI preferences file (on my machine it is at):
 c:/users/millighost/Application Data/Poser/8.0/English/Poser UI Prefs_1280x1024.xml
simply remove it while poser is not running, then it is back to factory state.
MadameX ( ) posted Sun, 21 August 2011 at 11:51 AM
Funny, after reading this thread, I had this happen to me last night. When I tried to move the library window around after making it floating, the right side 'stuck' to the right of the screen and only resized larger when I tried to move it. When I let it go, it docked above the doc window as in the OP's screenshot above. Messing around with it, I wound up with a tiny doc window and had to go into preferences to set poser back to default. That fixed it for me, but I don't think I'll be doing much floating with the ui anymore, even though it's cluttered, imo.
raven ( ) posted Sun, 21 August 2011 at 12:31 PM
Also, once you have your screen set up as you want, click on one of the UI Dots, then if it goes screwy again, you can click on the UI dot to get your preferred set up back.
MadameX ( ) posted Sun, 21 August 2011 at 1:00 PM
I also noticed that if you float the doc window, you can't do anything at all. What's the point of that?
Tracybee ( ) posted Mon, 22 August 2011 at 2:10 AM
Poser is not a friendly program.
It has gotten less user friendly and more unstable each time a new version arrives.
The User Interface now is so pathetic that I guess only porn producers will put up with it.
It used to be Ok years back when it came to be, but the new owners and their "staff"  still live in the 1980's. They haven't yet caught up and probably never will.
Philywebrider ( ) posted Mon, 22 August 2011 at 6:46 AM
I wanted to thank everyone for their help,, thank you. It is working now. Sorry I didn't get back sooner , I was ill. Ithink I ate something that didn't agree with me. Everyone's help was much appreicated.
Funny thing is, I don't know what caused the problem.
wimvdb ( ) posted Mon, 22 August 2011 at 7:03 AM
Quote - Poser is not a friendly program.
You either live in a different world or you are extremely insulting to a large group of people
geep ( ) posted Mon, 22 August 2011 at 9:03 AM
cheers,
dr geep ... :o]
edited 10/5/2019
Philywebrider ( ) posted Mon, 22 August 2011 at 12:06 PM
Why so sad Geep?
geep ( ) posted Mon, 22 August 2011 at 12:27 PM · edited Mon, 22 August 2011 at 12:33 PM
***geep sez: That is soooooooooooo SAD !!!!!!!!!!!!!***
geep responds *********************************************
I could not disagree more ... I have had more fun with Poser since it's inception than all other software that I have ... combined.
It makes me wonder if, when one has the attitude that is espressed above, one has not made any effort at all to learn anything at all about this most wonderful piece of software.
That's all. 😄
cheers,
dr geep ... :o]
edited 10/5/2019
mathman ( ) posted Tue, 23 August 2011 at 6:58 AM · edited Tue, 23 August 2011 at 6:59 AM
Quote - geep sez: That is soooooooooooo SAD !!!!!!!!!!!!!
That's all. 😄
Amen to that !
regards,
Andrew
geep ( ) posted Tue, 23 August 2011 at 8:25 AM · edited Tue, 23 August 2011 at 8:26 AM
Quote - I want the Hierachy window smaller and the Library window back on the right side and multi lines, (as in your sample )  Dr Gleep.
BTW - Who is Dr Gleep?
Does I have sum competition? :lol:
cheers,
dr geep ... :o]
edited 10/5/2019
Philywebrider ( ) posted Tue, 23 August 2011 at 9:41 AM
Oops! Gleep is an error in my typing. I use the Columbus Method, I discover a key, then land on it. I should know your name, you've helped me a number of times. There is no Bizarro Dr anywhere, ( I hope ). You and the other kind  people of renderosity are appreicated. Please accept my apology Doc, no disrespect intended.
geep ( ) posted Tue, 23 August 2011 at 10:06 AM
No apology need, I wuz just funnin' ya. :biggrin:
P.S. I used to have a keyboard like that and then I got a new one ... which is, sometimes, worse. :lol:
cheers,
dr geep ... :o]
edited 10/5/2019
SamTherapy ( ) posted Tue, 23 August 2011 at 10:17 AM
Garbage, on all counts.
Afrodite-Ohki ( ) posted Tue, 23 August 2011 at 2:38 PM
I wasn't aware I'm a porn star... oops, producer. LMAO!
Trolls be trollin'. And I be laughin'.
Feel free to call me Ohki!
