Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 12 9:45 pm)
Attached Link: http://www.puffs.com/index/index_flash.html
Here is the Puffs web site, with a small flash animation. Is that the kid you meant, Scott? http://www.puffs.com/index/index_flash.htmlI try to put my textures of a type in specified directory for that type (all Eve texture files go to an "eve" directory, etc). Poser seems to find assigned texts regardless of where I park them in the textures directory. But, given the fact that there is a path specified in the libraries directory, is it better to modify the cr2 or pp2 for the new path?
Gordon
Poser 4 seems to be a little better at finding textures if they are not in the specified locations. Pro Pack however, won't look if it's is not in the exact directory. While editing the CR2 and PP2 etc, is a good solution, it is also potentially disasterous for those who do not know what they are doing. If you understand how they work though, modifying the CR2 is a good way to customize your library. Thanks, Betsy DAZ Tech
I have 4.02 with ProPack and it has no trouble in finding textures in other than specified directories, although it takes a little time in loading. The only bother I have with that modification is that it won't create bump maps and it refuses to accept anything other than the specified bump map. I have another copy of ProPack that I use solely for producing bump maps. I have been considering moving all thirty gigs of data to that application, but won't now that you tell me that ProPack in it's pristine form won't accept textures in the wrong directory. Are you sure?
Gordon
Attached Link: http://www.daz3d.com
Hello Everybody! It's Betsy from DAZ, back with another Tech Tip, "Managing Your Poser Library". You can veiw it on our website or on the Front Page here in a few days. Thanks eveyone for your support! Enjoy!! Betsy Schow DAZ Tech tech@daz3d.com
