Thu, Nov 14, 5:47 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 13 11:02 am)
Subject: How to I make a resistance band for exercise education tutorials, eg rotator cuf
divingbuddah ( ) posted Tue, 30 August 2011 at 9:35 PM · edited Wed, 13 November 2024 at 11:05 AM
I what to make some short animations and stills of exercises using resistance tubes and cable pulls.
Both ends of the tube need to be fixed, one end to a tie off the other to the figure's body somewhere. How can a prop be made to adjust when both 'fixed' ends vary in their relationships with each?
FYI if the cloth room is the solution, I need step by step help since I am a cloth room virgin.
thanks for any ideas.
geep ( ) posted Tue, 30 August 2011 at 9:46 PM · edited Tue, 30 August 2011 at 9:51 PM
*(click image to view full size)*
Would something like this work?
It could be used for linear motion, i.e. rubber band stretch,  as well as radial motion.
cheers
dr geep
cheers,
dr geep ... :o]
edited 10/5/2019
markschum ( ) posted Tue, 30 August 2011 at 10:18 PM
you can make a prop morph for the short and long positions. That could even be done in Poser with magnets and then spawn a morph from it. It would depend on how many positions you would need. A figure with handle-spring-handle would be easy to make.
Miss Nancy ( ) posted Wed, 31 August 2011 at 12:01 AM
those things may be the kind of elastic tubes that get thinner as they stretch.  like extra-large latex surgical tubing.  they can't use springs, as they pinch yer skin if yer not careful.
