Have you looked at ShareCG?
http://www.sharecg.com/v/16846/View/5/3D-Model/headphones-prop
http://www.sharecg.com/v/43157/View/11/Poser/Headphones-for-Aiko-4-Smartprop
http://www.free3dmodelz.com/3d-accessories/3d-headphones/
http://www.turbosquid.com/FullPreview/Index.cfm/ID/548392
Object files can be imported into Poser. Go to "File" and then "Import" and pick "Wavefront Object"
If you find .3ds Max files, those can also be imported.
say." - Ghandi
Quote - [quotte]If you find .3ds Max files, those can also be imported.
.3ds files can be imported into poser? Does this mean the material will also be imported or will I need to correct the material after I import it?
I can't remember. Try it and find out. The worse that will happen is that you will have to delete the object from the preview window.
.3ds files can be imported. The .max file extensions can't be.
say." - Ghandi
I'm looking for some cool headphones for Poser. I have found some at turbo squid but they are all in .obj format and most are very expensive. I'm looking for the Big Headphones that people used to wear in the 70's, but with more of a modern style, big but modern. I found two models on renderosity, but I'm hoping that someone knows of other places that may have them other than turbo squid.
