Fri, Nov 22, 9:16 PM CST
Subject: In Search of Cool Headphones
FightingWolf ( ) posted Tue, 13 September 2011 at 3:26 AM · edited Fri, 22 November 2024 at 9:13 PM
I'm looking for some cool headphones for Poser.  I have found some at turbo squid but they are all in .obj format and most are very expensive.  I'm looking for the Big Headphones that people used to wear in the 70's, but with more of a modern style, big but modern.  I found two models on renderosity, but I'm hoping that someone knows of other places that may have them other than turbo squid.
Acadia ( ) posted Tue, 13 September 2011 at 8:52 AM
Have you looked at ShareCG?
http://www.sharecg.com/v/16846/View/5/3D-Model/headphones-prop
http://www.sharecg.com/v/43157/View/11/Poser/Headphones-for-Aiko-4-Smartprop
http://www.free3dmodelz.com/3d-accessories/3d-headphones/
http://www.turbosquid.com/FullPreview/Index.cfm/ID/548392
Object files can be imported into Poser.  Go to "File" and then "Import" and pick "Wavefront Object"
If you find .3ds Max files, those can also be imported.
adroge ( ) posted Tue, 13 September 2011 at 12:18 PM
If I remember correctly, I think you can get the headphones on the Marie Elite character somewhere in the DAZ3D store. I think that's what you might be looking for. It might be part of a hair product. I could be wrong, but maybe it give you a place to start looking.
FightingWolf ( ) posted Tue, 13 September 2011 at 1:24 PM
[quotte]If you find .3ds Max files, those can also be imported.
.3ds files can be imported into poser? Does this mean the material will also be imported or will I need to correct the material after I import it?
Acadia ( ) posted Tue, 13 September 2011 at 4:00 PM
Quote - [quotte]If you find .3ds Max files, those can also be imported.
I can't remember.  Try it and find out. The worse that will happen is that you will have to delete the object from the preview window.
.3ds files can be imported.    The .max file extensions can't be.
