Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2025 Feb 05 6:41 am)
this is what i get
Traceback (most recent call last):
File "D:3dpythonFigure to Prop.py", line 10, in ?
from Tkinter import *
File "C:Program Files (x86)Smith MicroPoser Pro 2010RuntimePythonliblib-tkTkinter.py", line 38, in ?
import _tkinter # If this fails your Python may not be configured for Tk
ImportError: DLL load failed:
Quote - That error usually means that the Poser Python has been damaged (most likely known cause is having installed the standalone Wardrobe Wizard into the Poser directory), you have another install of Python that's interfering with Poser's, or there's a missing DLL.
i have blender on my computer. i think python is inside. could this be the problem?
Quote - > Quote - msvcr71.dll was missing under runtime/python/dlls
That should only be a problem for the 32-bit version of PPro2010, if the problem was occuring with the 64-bit version, then something else is awry.
No that was also the problem for the 64bit version too. I had the same situation and it disappeared after copying the *.dll into the specific Python folder (DLLs). The problem vanished in PP2012.
i have poser pro 2010 and i think the script doesnt work with the latest poser. can someone try it out if its my computer?
http://www.renderosity.com/mod/freestuff/details.php?item_id=50705
could someone update the script for Poserpro 2010?
thanks
