Sun, Feb 16, 9:53 AM CST
Forum Moderators: Staff
Poser Python Scripting F.A.Q (Last Updated: 2025 Feb 05 6:41 am)
Subject: Figure to Prop (Dimension3D)
ice-boy ( ) posted Sun, 21 August 2011 at 3:00 AM · edited Sat, 15 February 2025 at 9:08 PM
i have poser pro 2010 and i think the script doesnt work with the latest poser. can someone try it out if its my computer?
http://www.renderosity.com/mod/freestuff/details.php?item_id=50705
could someone update the script for Poserpro 2010?
thanks
semidieu ( ) posted Sun, 21 August 2011 at 3:27 AM
What does this script ?
Convert the file from a figure (.cr2) to a prop (.pp2) ?
Or a Poser figure to a Poser prop ?
I'm sure D3D will jump here and check what's going on :)
nruddock ( ) posted Sun, 21 August 2011 at 8:35 AM
Quote - ... i think the script doesnt work with the latest poser ...
What error messages are you getting ? If you're not getting error messages, give details of what does or doesn't happen or works differently than previously.
markschum ( ) posted Sun, 21 August 2011 at 10:02 AM
Rhat script appears to have been written in 2008 for Poser 5
it uses tkinter for the interface and one line reads
Label(self.frame, text="Name").grid(row=0, column=0)
I believe that all references to column need to change to col but you should be getting n error that points to the line thats wrong.
ice-boy ( ) posted Wed, 14 September 2011 at 4:52 AM
this is what i get
Traceback (most recent call last):
  File "D:3dpythonFigure to Prop.py", line 10, in ?
    from Tkinter import *
  File "C:Program Files (x86)Smith MicroPoser Pro 2010RuntimePythonliblib-tkTkinter.py", line 38, in ?
    import _tkinter # If this fails your Python may not be configured for Tk
ImportError: DLL load failed:
nruddock ( ) posted Wed, 14 September 2011 at 3:30 PM
That error usually means that the Poser Python has been damaged (most likely known cause is having installed the standalone Wardrobe Wizard into the Poser directory), you have another install of Python that's interfering with Poser's, or there's a missing DLL.
ice-boy ( ) posted Thu, 15 September 2011 at 12:34 PM
is this python installed inside poser? or do we have to do it ourself?
ice-boy ( ) posted Thu, 15 September 2011 at 12:37 PM
Quote - That error usually means that the Poser Python has been damaged (most likely known cause is having installed the standalone Wardrobe Wizard into the Poser directory), you have another install of Python that's interfering with Poser's, or there's a missing DLL.
i have blender on my computer. i think python is inside. could this be the problem?
markschum ( ) posted Thu, 15 September 2011 at 7:21 PM
try putting the script in the poser python folder and run it from there.
ice-boy ( ) posted Fri, 16 September 2011 at 9:25 AM
Dimension3D found the problem
msvcr71.dll was missing under runtime/python/dlls
nruddock ( ) posted Fri, 16 September 2011 at 6:48 PM
Quote - msvcr71.dll was missing under runtime/python/dlls
That should only be a problem for the 32-bit version of PPro2010, if the problem was occuring with the 64-bit version, then something else is awry.
mackis3D ( ) posted Wed, 19 October 2011 at 12:43 PM
Quote - > Quote - msvcr71.dll was missing under runtime/python/dlls
No that was also the problem for the 64bit version too. I had the same situation and it disappeared after copying the *.dll into the specific Python folder (DLLs). The problem vanished in PP2012.
