Sat, Nov 30, 8:18 PM CST
DAZ|Studio F.A.Q (Last Updated: 2024 Nov 29 12:43 am)
Subject: Invisible Content in DS 4.0.0.343
Ninja-G33k ( ) posted Fri, 16 September 2011 at 2:56 PM · edited Thu, 28 November 2024 at 3:57 AM
I have a folder full of content (and I keep stumbling across more) that appears to be invisible (I've tested every piece in the folder) when I load it it into DAZ Studio 4.0.0.343.
The Scene tab tells me that the figure has loaded, and a marker appears in the main viewing pane, but nothing else appears, no surfaces, nothing; it's like the bones are there but there's no skin covering them.
I moved on to importing the OBJ files, and those show up fine.  I'm quite baffled.
The really strange thing is that all this stuff worked fine when I was using DAZ Studio 2.3.
Any assistance is greatly appreciated.
TheHalfdragon ( ) posted Fri, 16 September 2011 at 3:00 PM
that is happening to alot of stuff in DS4 regular too things that load fine and fully in DS2.3 and DS3.1A aswell.
RHaseltine ( ) posted Fri, 16 September 2011 at 3:10 PM
If you reset your DS4 order the new version should be OK - it was a group naming issue (DS4 is fussier) and they've implemented a workaround, certainly DS Pro/Advanced was OK.
TheHalfdragon ( ) posted Fri, 16 September 2011 at 3:30 PM
i know a cpl people with ds4 pro upgrade that say it's pretty glitchy too so i'll suggest to them to try the reset to newer version
Ninja-G33k ( ) posted Fri, 16 September 2011 at 3:51 PM
Quote - If you reset your DS4 order the new version should be OK - it was a group naming issue (DS4 is fussier) and they've implemented a workaround, certainly DS Pro/Advanced was OK.
  And  all I need to do is install the new one over my existing one?
TheHalfdragon ( ) posted Fri, 16 September 2011 at 6:56 PM
yeah that would be the thing you did it will uninstall it as it installs the newer version
Ninja-G33k ( ) posted Fri, 16 September 2011 at 7:35 PM
Huzzah!
Problem solved!
