Vue F.A.Q (Last Updated: 2024 Oct 26 8:50 am)
Any software firewalls enable on the computers that could block them from seeing each other?
Interim solution:
per original post, no firewalls enabled, and on a separate, non-internetted wired 1000 mbps network.
Within each node's render cows, there is an "auto-discovery port" 5591 and a "command port" 500X. Though the IP addresses keep changing (hmmmmm....... ; will perhaps need a different switch), giving each node a distinct command port address and corresponding Hyper Vue address - though dodgy, at the moment - has me now seeing 3/5 nodes so I'm getting closer, though not yet seeing the speed gains I'd hoped for....
But why doesn't HyperVue (8.0) open as it's own executable (for offline / pre-render confirguration), rather than as an online Vue utility? ARGH!!!!
Are you using DHCP or static for the IP address assignment on each computer?
You need to plug your computers into a router then to assign their IPs automatically. Or assign each computer its own static IP:
192.168.2.20 (main computer)
192.168.2.21 (render node)
192.168.2.22 (render node)
192.168.2.23 (render node)
192.168.2.7 (printer/scanner)
192.168.2.10 (network backup drive)
192.168.2.11 (backup of the backup)
etc.
Success!!!
(1) each cow receives its own command port
(2) each system receives its own static IP. Not crazy about the idea but it works.
Cerro Verde.vue, rendered internally: 13m49s
Cerro Verde.vue, one node external: 18m18s
Cerro Verde.vue, five nodes external: 03m38s
Definitely worth the investment in time.
Apologies if this question has already been answered but a hasty search through the forums hasn't provided the answer yet.
I've just set up a small network of render cows but I can't get Hyper Vue to successfully connect to them. This is a network of macs, though the platform (I think) shouldn't matter.
Each computer has a render cow installed, opened and presumably running. Hyper Vue says they are "disconnected" when I search the systems by name or IP address. As far as I can tell, there are no firewalls enabled, the ports are set to default, "desktop sharing" is enabled, and I have no difficulties browsing the systems with Finder (the equivalent of Windows Explorer).
Browsing the archives I noticed that a render cow must be installed on the host - will try that next - but open to other ideas and suggestions. Thanks in advance.
