Wed, Nov 20, 1:21 AM CST
Vue F.A.Q (Last Updated: 2024 Oct 26 8:50 am)
Subject: Render Cows not working
replicand ( ) posted Mon, 19 September 2011 at 4:43 PM · edited Fri, 15 November 2024 at 6:25 PM
Apologies if this question has already been answered but a hasty search through the forums hasn't provided the answer yet.
I've just set up a small network of render cows but I can't get Hyper Vue to successfully connect to them. This is a network of macs, though the platform (I think) shouldn't matter.
Each computer has a render cow installed, opened and presumably running. Hyper Vue says they are "disconnected" when I search the systems by name or IP address. As far as I can tell, there are no firewalls enabled, the ports are set to default, "desktop sharing" is enabled, and I have no difficulties browsing the systems with Finder (the equivalent of Windows Explorer).
Browsing the archives I noticed that a render cow must be installed on the host - will try that next - but open to other ideas and suggestions. Thanks in advance.
Dale B ( ) posted Mon, 19 September 2011 at 10:06 PM
You have to add the mac's by IP address into the hypervue manager. Delete what's there, then add them one at a time. It just seems to be a peculiarity of the rendercow system (unless they changed it, of course. I'm on windows, so I can only repeat other solutions I've heard about).
replicand ( ) posted Mon, 19 September 2011 at 11:21 PM
Will try and report back.
Prior to reading your response, tried changing settings in the router - I can see the host + 1 render cow, but don't know why the other three aren't showing. No worries; the time I invest here will be well worth the time I will save, no?
ShawnDriscoll ( ) posted Tue, 20 September 2011 at 12:17 AM
Any software firewalls enable on the computers that could block them from seeing each other?
replicand ( ) posted Wed, 21 September 2011 at 7:13 PM · edited Wed, 21 September 2011 at 7:15 PM
Interim solution:
per original post, no firewalls enabled, and on a separate, non-internetted wired 1000 mbps network.
Within each node's render cows, there is an "auto-discovery port" 5591 and a "command port" 500X. Though the IP addresses keep changing (hmmmmm....... ; will perhaps need a different switch), giving each node a distinct command port address and corresponding Hyper Vue address - though dodgy, at the moment - has me now seeing 3/5 nodes so I'm getting closer, though not yet seeing the speed gains I'd hoped for....
But why doesn't HyperVue (8.0) open as it's own executable (for offline / pre-render confirguration), rather than as an online Vue utility? ARGH!!!!
ShawnDriscoll ( ) posted Wed, 21 September 2011 at 9:01 PM
Are you using DHCP or static for the IP address assignment on each computer?
replicand ( ) posted Thu, 22 September 2011 at 8:36 AM
Currently using DCHP, but Hyper Vue and the switch are reporting wildly different IP addresses. One reports 10.1.x.x while the other reports 192.168.x.x. Weird.
ShawnDriscoll ( ) posted Thu, 22 September 2011 at 6:42 PM
You need to plug your computers into a router then to assign their IPs automatically.  Or assign each computer its own static IP:
192.168.2.20 (main computer)
192.168.2.21 (render node)
192.168.2.22 (render node)
192.168.2.23 (render node)
192.168.2.7 (printer/scanner)
192.168.2.10 (network backup drive)
192.168.2.11 (backup of the backup)
etc.
replicand ( ) posted Fri, 23 September 2011 at 1:42 PM
Success!!!
(1) each cow receives its own command port
(2) each system receives its own static IP. Not crazy about the idea but it works.
Cerro Verde.vue, rendered internally: 13m49s
Cerro Verde.vue, one node external: 18m18s
Cerro Verde.vue, five nodes external: 03m38s
Definitely worth the investment in time.
ShawnDriscoll ( ) posted Sat, 24 September 2011 at 5:21 AM
