Thu, Nov 14, 2:12 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 14 12:36 pm)
Subject: Rendering issue
IdolStar ( ) posted Fri, 23 September 2011 at 3:08 PM · edited Thu, 14 November 2024 at 2:02 PM
Hello,
Today i was trying out a new product that i had gotten but when rendering it. I was finding redesh black marks on the skin. Tryed diffrent skin texture and bumps but still have this issue.. I have no clue whats causing never had this happen before
FightingWolf ( ) posted Fri, 23 September 2011 at 3:28 PM
redish black marks like blemishes?
kirwyn ( ) posted Fri, 23 September 2011 at 5:28 PM
Could be a polygon issue. Try unchecking smooth polygons in render palette. If that's not it, try adjusting your shadow light or lights (Shadow Min Bias) via the the Parameter's palette.
IdolStar ( ) posted Fri, 23 September 2011 at 6:53 PM
This is what am geting on the leg.. But if i set my render to the lowest setting then it comes out fine.
ToxicWolf ( ) posted Fri, 23 September 2011 at 7:31 PM
I had a problem like that and it turned out to be a memory issue. I had too many figures and textures in my frame for my machine to manage. I ran some of the old pz3 files on my new machine with 24 gig of ram and it cleared up. Not sure if that's what yours is doing though.
Poser Pro 2012 SR3
Windows 7 Professional 64 bit
Intel Core I7 990x 3.46G 6 core
24G RAM
EVGA GTX580 R Video Card
Single HP LP2475 1920x1200 monitor
______________________________
http://www.toxicwolf.com
rokket ( ) posted Fri, 23 September 2011 at 7:40 PM
Jeez, I just have 4GB of ram, and a core two duo processor... But I have not had that issue. So, I can be no help other than say that I don't think it's a memory issue. It may be a problem with the polys on the model itself.
vilters ( ) posted Fri, 23 September 2011 at 7:48 PM
What happens if you remove texture filtering? => set to none.
What happens if you put texture filtering to quality?
FightingWolf ( ) posted Fri, 23 September 2011 at 11:01 PM
I had a similar problem in the past and they only showed up when I rendered in different settings.  My solution was to adjust the lighting a little by moving the light position, and it went away.  To this day I have no idea what was going on.
My guess is that the file I was using some how became corrupt and caused the problem.  I'm saying that because I think I opened a new window and used a new load of the model and the texture and the problem didn't occur with the new load of the model.
Teyon ( ) posted Sat, 24 September 2011 at 1:41 AM
Try turning off Smooth Polygons in your render if it's turned on and see if that helps.
IdolStar ( ) posted Sat, 24 September 2011 at 5:35 AM
I will give everything a try today.
IdolStar ( ) posted Sat, 24 September 2011 at 9:39 AM
> Quote - Try turning off Smooth Polygons in your render if it's turned on and see if that helps.
This seems to have made it better but still haveing some issue
The skin am useing is for a product am working on to sell here so would a buyer have this issue?
