Wed, Jan 8, 12:31 AM CST
Forum Moderators: Staff
Subject: What precisly is a "bone"?
lesbentley ( ) posted Sun, 25 September 2011 at 11:59 AM · edited Wed, 08 January 2025 at 12:25 AM
What precisly is a bone?
A lot on people talk about Poser bones. I spend a lot of time messing around inside Poser libeary files, but have never seen anything named "bone" in any one of them. Of couse I know that it has something to do with the Setup Room (which I never use), and those triangular icins.
But what in precise technical terms is a bone? Is it the entire actor in all sections of the cr2; morphs, crease angle, 'addChild' stuff, weld statement, geometry assignment,  the whole kit and cboodle? Or is it some subset of the above, and if a subset, what exactly is included in, or excluded from the subset?
I have wondered about this for a long time. I've been kind of embarrised to ask. I assumed that one day the meaning would become clear to me, but it never has. So please, your best stab at a precise technical definition of the word "bone".
nruddock ( ) posted Sun, 25 September 2011 at 4:21 PM
Quote - But what in precise technical terms is a bone?
It's a named element of a the skeleton hieracrchy.
It has a start point, an end point, a name, and a transformation relative to it's parent.
Quote - Is it the entire actor in all sections of the cr2; morphs, crease angle, 'addChild' stuff, weld statement, geometry assignment,  the whole kit and caboodle?
Everything else is part of the actor with which the bone is associated.
EnglishBob ( ) posted Sun, 25 September 2011 at 5:19 PM
To add an aside to that - Poser's concept of a bone is really nothing more than a means of picturing the joint centres and the hierarchical relationships when using the setup room. I don't recall the term being used before Pro Pack (the first version with a setup room included) was released. As such, it only goes part of the way way towards describing what happens when a joint bends. As nruddock says, the rest of the important stuff is covered by the concept of the actor.
I understand that other 3D application's rigs have a more comprehensive skeleton, but I know nothing about them so should probably avoid saying any more. ;)
Kazam561 ( ) posted Tue, 01 November 2011 at 11:52 PM
Thank you for the explaination. I appreciate them :)
The dust settled, thinking "what a fine home, at least for now" not realizing that doom would soon be coming in the form of a vacuum cleaner.
