Fri, Mar 6, 6:11 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2026 Mar 05 8:06 pm)
Subject: Poser 9 - Do You Need Internet Connection to See Libraries???
pigfish9 ( ) posted Thu, 29 September 2011 at 4:46 PM · edited Fri, 27 February 2026 at 3:19 AM
I refuse to connect my Poser PC to the internet after losing a ton of material to a virus several years ago.  (I will never trust McAfee again!)   I was never able to use Poser 8 because of the ActiveX setup for the libraries.  They just won't show up.  Is Poser 9 set up the same way?  If so, I'll stick with 7and spend my money on content instead of software.  Thank you!
Diogenes ( ) posted Thu, 29 September 2011 at 5:20 PM
You never did need the internet even with P8 you simply dont have the correct version of Adobe flash and or Air installed or your firewall Av is blocking access.. I know because I also never connect my Poser machine to the internet, and I have been using P8, Pro2010, P9, and Poser2012 all this time. Great library and no problems. Get the correct download for flash player (the full download) and your problems are solved.
Befor you start in with "well Poser 8 library wants to use the internet" No it does not, it uses your PC home addres which does not have anything to do with being connected to  the internet. Everyone has the same PC home adress.
There are gads of threads on this subject from P8 times. I think BB answered this question till he was blue in the face. So there is a wealth of info at your disposal.
A HOMELAND FOR POSER FINALLY
LaurieA ( ) posted Thu, 29 September 2011 at 5:24 PM
Diogenes is correct...Poser 8 never did "dial home", just the local host ;).
pigfish9 ( ) posted Thu, 29 September 2011 at 5:31 PM
I tried all the fixes but every time Poser put out an update it undid the fixes.  So, 9 still uses Flash which still has to be updated from Adobe all the time which requires going to the Internet, right?
bagginsbill ( ) posted Thu, 29 September 2011 at 5:35 PM
Stop saying whatever you think.
It uses Flash. It does not need to be updated all the time. In fact, if you install the one it is intended for and disconnect from the network forever, your machine will never ever need another copy of Flash.
bagginsbill ( ) posted Thu, 29 September 2011 at 5:40 PM · edited Thu, 29 September 2011 at 5:40 PM
I thought Poser installed it for you, but if it did not, just go to a computer at your library - a computer you are OK with destroying by connecting to the Internet. Be sure to wear gloves.
Go to the Adobe site. Instead of installing, just do Save As and save the installer.
Burn it to CD.
Wash your hands.
Put on new gloves.
Take the CD home.
Install Flash.
Burn the CD. This time I mean set it on fire with a lighter. Gasoline may help with this.
Spray your computer for bugs.
alexcoppo ( ) posted Thu, 29 September 2011 at 5:44 PM
At worst, you will get an error message in the library window; click OK (or whatever the button is) and go ahead without problems.
GIMP 2.7.4, Inkscape 0.48, Genetica 3.6 Basic, FilterForge 3 Professional, Blender 2.61, SketchUp 8, PoserPro 2012, Vue 10 Infinite, World Machine 2.3, GeoControl 2
hborre ( ) posted Thu, 29 September 2011 at 5:48 PM · edited Thu, 29 September 2011 at 5:49 PM
IIRC, the Flash installation is accessible from the install window upon autoplay or install execution.
TrekkieGrrrl ( ) posted Thu, 29 September 2011 at 6:46 PM
Quote - I thought Poser installed it for you, but if it did not, just go to a computer at your library - a computer you are OK with destroying by connecting to the Internet. Be sure to wear gloves.
Burn it to CD.
Wash your hands.
Put on new gloves.
Take the CD home.
Install Flash.
haha
nruddock ( ) posted Thu, 29 September 2011 at 7:23 PM
You could even use the Flash installer (AutoPlay/Docs/install_flash_player_ax.exe) that came with P8 and PPro2010.
The same goes for Adobe Reader.
BDDesign ( ) posted Thu, 29 September 2011 at 7:24 PM
You could have also just installed an alternative library.
icprncss2 ( ) posted Thu, 29 September 2011 at 10:37 PM
Does Pro 2012 use Air or Flash?  Do you have to have both installed?
bantha ( ) posted Fri, 30 September 2011 at 1:23 AM
The Pro 64bit uses Air, because Flash is still in beta for 64bit Windows. You can install the beta and switch the library to Flash instead of Air if you like to.
-"Amazing Grace" Hopper
pigfish9 ( ) posted Fri, 30 September 2011 at 1:26 PM
So, in a nutshell, Poser 9 still uses Flash and, if I have Flash issues, I will have issues with Poser 9.  That's all I needed to know.  I did get Poser 8 working, once, and then I installed the update and it quit working.  I tried the flash help instructions from here and still couldn't get the libraries to come back and gave up.  Maybe it was a Norton's issue even though I told it to disable the firewall.  I just know that Poser 7 works fine and Poser 8 doesn't.  I just bought a new PC (two weeks ago) that has the new Adobe Photoshop (the lite version--not the CS-4).  I haven't tried Poser 8 yet.  Do you think it will have a version of Flash that will work?
bagginsbill ( ) posted Fri, 30 September 2011 at 1:28 PM
It is a Norton issue, I think. Robbybobby has the same problem and we're going to try to fix it with me remotely operating his computer.
I did some research on Norton configuration dialogs. How confusing. I don't expect anybody could figure it out by you telling them what is or is not in front of you. I'm hoping that with me actually seeing it and operating it, I'll sort out what the issue is.
I can tell you from the little bit of Googling I've done looking at Norton configuration dialogs, that is a program that you should not be using unless you're very technical.
bagginsbill ( ) posted Fri, 30 September 2011 at 1:35 PM
In my research, it looks like Norton completely changes their configuration user interface just about every year. So I cannot even point you to something general.
Here's a page describing how to fix it for a program called nmsrvc from Pure Networks.
I don't know what that program is, but Norton messes it up. If that is your version, and the dialogs look like that, try the same instructions, only you want to do it for Poser.exe, not the program discussed on that page.
http://www.purenetworks.com/support/faq/150.html
bagginsbill ( ) posted Fri, 30 September 2011 at 1:36 PM
I just want to add, that your firewall is not protecting you by interfering with Poser - it is not needed. Poser only has one listening port open, and it will not accept a connection from outside your machine. In other words, it has "firewall" style rules built into it, even if you have no firewall at all.
bagginsbill ( ) posted Fri, 30 September 2011 at 4:19 PM · edited Fri, 30 September 2011 at 4:20 PM
I just found the problem for Rob. Posted this at RDNA. I'm posting it here as well, as a general FYI.
Good news. Rob let me into his computer and I found the problem.
It was not Norton.
I wasted some time trying to configure Norton to allow Poser to work. No joy.
I completely disabled Norton and still got connection refused on that port.  No joy.
I verified that the Windows firewall was disabled as well. No firewalls running, still no joy.
Hmmm.
Downloaded Microsoft Sys Internals utility TCPView to see who had port 11530 open. It was AOL!!!!
Rob had long ago used AOL but he removed it - or so he thought. There was this one program:
aoltpspd.exe
That had a BUNCH of ports open, just grabbed them for no reason. One of them was the Poser port 11530.
I killed this program and Poser and its library WORKED PERFECTLY.
Even with the Norton firewall turned back on, the library WORKED PERFECTLY.
So - the problem is AOL Communication Services. The program aoltpspd.exe is stealing ports and this prevents Poser from working.
I looked up in several TCP registries to see which company had registered their use of port 11530. Neither SM nor AOL had done so.
So - if you have problems, look in Task Manager for aoltpspd. If you see it you need to uninstall AOL Communications Services.
And this is AOL Topspeed, specifically. If you don't need that then get rid of it. It's evil.
pigfish9 ( ) posted Fri, 30 September 2011 at 7:44 PM
Thank you.  I'll look for that program.   I don't want Norton's but HP sticks it on there whether you want it or not--bleh.   The computer companies add so many progrms you never use to new PCS that just hog memory and sometimes cause problems.  I'm sure they get paid to include it which, theoretically, keeps the price of the PC down.
I love Poser and want to stay up-to-date.  I'll try installing 8 this weekend and see if it works.  If I can see the libraries in 8, I should be able to see them in 9, I hope.
Tucan-Tiki ( ) posted Thu, 06 October 2011 at 7:19 PM · edited Thu, 06 October 2011 at 7:20 PM
I can say this, zone alarm hates poser 8, i had to shut it off to get the damn libraries to load.
but after poser 8 kept crashing I just said the hell with it and went back to poser 7 and only use 8 if I need it's capabilities
FightingWolf ( ) posted Thu, 06 October 2011 at 7:40 PM
Quote - I refuse to connect my Poser PC to the internet after losing a ton of material to a virus several years ago.  (I will never trust McAfee again!)   I was never able to use Poser 8 because of the ActiveX setup for the libraries.  They just won't show up.  Is Poser 9 set up the same way?  If so, I'll stick with 7and spend my money on content instead of software.  Thank you!
McAfee isn't a bad program, but you can't just trust 100% in any anti-virus program. Avoid risky downloads, never click on email links or open emails from sites that you don't deal with. ALWAYS have 2 different emails that you use (One for junk and other for business only).  I get bank emails all the time through hotmail, but I don't use my hotmal address for serious purposes, so I know right away not to even bother.
Highly recommended not to use hacked, cracked, or warez programs because that only opens the door that any anti-virus program won't be able to close. I could go through 50 things that the user should do in order to avoid virus before even getting to the anti-virus settings that should be used. Such as configuring firewalls and program permissions. I could go through all of the spyware preventions as well.
The reason I'm mentioning this because it appears that you are completely blaming it on McAfee.  I've seen all types of anti-virus programs fail, and it wasn't the software's fault, it was the user that made it possible for the virus to work it's way in.
If you are depending on the Antivirus 100% then all I can say is just get ready to lose some more information from your hard drive.
FightingWolf ( ) posted Thu, 06 October 2011 at 7:52 PM
Quote - I can say this, zone alarm hates poser 8, i had to shut it off to get the damn libraries to load.
Zone alarm has never played friendly with other software and that has been the common issue since day one when they first came out.
LaurieA ( ) posted Thu, 06 October 2011 at 9:33 PM · edited Thu, 06 October 2011 at 9:33 PM
Use Comodo Firewall. Problem solved ;). It plays nice.
