Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 20 6:12 am)
Why is Ppro 2012 slow when loading ?
Nothing to do with the graphic card ...
The good answer is :
When you load a prop or a figure it pre-load all the textures for speeding render.
When you delete a prop or a figure it delete all the textures too.
These two only if the texture is not used on another prop.
When you start a new scene it delete all the textures, no more "ALT-F4" for cleanup the ram.
Génération mobiles Le Forum / Le Site
Well your answers are all well and good, but my Poser 7 does it much quicker and that can't take advantage of a 64 bit machine like Pp2012 can..
Poser 7 is faster than this new version at the moment..Fact.
I also have Poser 8 installed and that's faster too..
Injustice will be avenged.
Cofiwch Dryweryn.
I'm not talking about rendering, I don't render inside Poser that much. I'm talking about loading for example V4, once she's in the scene the app becomes stalled for a number of seconds before responding again..It's always the same when adding to a scene or even a blank workspace for that matter..
Cofiwch Dryweryn.
I also do NOT talk about rendering.
In the render settings, switch to the preview tab - there you can turn off HW Shading
This is the settings which improves the preview display with shadows and shaders.
Poser 8 had this setting off as default. (HW Shading was not as good as P9's, so it was not used as much). P9 has it set on by default
I'm finding it very slow to use, load a figure and it takes quite a few seconds after it's loaded for me to move a camera or anything..
Cloth room is also very slow to calculate, it gets there but it's a lot slower than my P7 was..
Anyone else having speed issues??
Box specs..
Quad core Q6600, 8 Gig RAM, Nvidia 9800GT with 1 Gig on board RAM..
Cofiwch Dryweryn.
