Sat, Feb 8, 1:02 PM CST
Subject: Poserfusion?
madriver ( ) posted Sat, 01 October 2011 at 6:06 PM · edited Sat, 08 February 2025 at 11:00 AM
Anyone know what the holdup is with the poserfusion plugs? SM says "coming soon" for about 3 weeks now! Hate paying for something I haven't gotten...annd zero word from the publisher...
corinthianscori ( ) posted Sun, 02 October 2011 at 9:04 AM
I don't know what the holdup is either. Poserfusion that I have doesn't work in Max 2010 for some reason... an update would be great, SM!
gypsoid ( ) posted Tue, 04 October 2011 at 8:37 AM
PoserFusion for Cinema 4D and Lightwave have just been published. Refresh page if links do not appear.
http://poser.smithmicro.com/poserfusion.html
My experience so far with C4D 12 and 13 64 bit plugins under Win 7 64 bit is immediate "not responding" and hard crash. All updates applied (system, video, Poser and Cinema). Tried loading a base V4.2 saved out with, then without external binary morphs.
But anyhoo, the plugins are there. Hope you better luck than me.
madriver ( ) posted Tue, 04 October 2011 at 9:40 AM
Hi gypsoid: the current updates posted for C4D only work with 9-11.5. It works great in my 11.5 but crashes in 12.
I just got word from Smith Micro this morning that the new poserfusion updates will be posted sometime this week. These should work with 11-13.
gypsoid ( ) posted Tue, 04 October 2011 at 10:13 AM
madriver thank you so much for this info! I'll run my 10.5 and 2010 for just a wee bit longer then. Saved me a bunch of time - appreciate.
pappy411 ( ) posted Tue, 04 October 2011 at 11:52 AM
Is poser fusion not going to be for C4D v10? Looks like it only supports v11 on up. Really a sad situation when program versions go out of date with lack of support so soon. some of us can't afford constant updates of ALL 3d programs.
madriver ( ) posted Tue, 04 October 2011 at 11:58 AM
Hi Pappy411: the poserfusion for 2010 should work for v10. Not sure if the 2012 poserfusion update will work for c4d 10/10.5 though.
pappy411 ( ) posted Tue, 04 October 2011 at 5:19 PM
Thank you madriver.  I am new to Poser Pro.  Prior to PP2012 I only used the Poser versions.  Is there a link available for the 2010 version of Poser fusion?
madriver ( ) posted Tue, 04 October 2011 at 9:51 PM
Quote - Thank you madriver.  I am new to Poser Pro.  Prior to PP2012 I only used the Poser versions.  Is there a link available for the 2010 version of Poser fusion?
Yes. If you go here:
and scroll down a few paragraphs, it should be there, along with all the other updates for all poser versions.
pappy411 ( ) posted Wed, 05 October 2011 at 7:44 AM · edited Wed, 05 October 2011 at 7:45 AM
Not having much luck. found just Fusion 2012. Nothing about fusion 2010. I googled Poser Fusion 2010 but only found versions that required payments and appeared to be questionable web sites.
madriver ( ) posted Wed, 05 October 2011 at 10:11 AM
Quote - Not having much luck. found just Fusion 2012. Nothing about fusion 2010. I googled Poser Fusion 2010 but only found versions that required payments and appeared to be questionable web sites.
Sorry, I gave you the wrong url. Try this one:
http://poser.smithmicro.com/updates.html
pappy411 ( ) posted Wed, 05 October 2011 at 4:03 PM
I only had Poser 8 and not PP2010.  It appears I need to have a PP2010 serial number to download the Fusion 2010.  My PP2012 serial number is not accepted.
Thank you for your help.
Pappy
