Mon, Feb 3, 10:01 PM CST
Subject: Poser 7 render crashes!!
meltz ( ) posted Thu, 29 September 2011 at 5:33 PM · edited Mon, 03 February 2025 at 9:58 PM
I have been working on a scene for months now. I have even rendered a bunch of pictures from this scene in the past. Today when i click render it CRASHES!! It reads all the maps and shadow maps but once its ready to start the render it crashes =-(
Any clue how to fix this?
Rance01 ( ) posted Thu, 29 September 2011 at 6:20 PM
I've had this happen (with small files) and after re-building the scenes from scratch was able to render them fine.  I thought the file(s) had somehow got corrupted.  Are you able to load the scene into a text editor and scan for errors?  Do you have earlier versions of the file?
Somethings you might be able to try is changing your render settings, clearing away any cache files and/or temp files.  I know I still have hair sets that don't play well with certain of my saved light sets.  Some combinations simply can't be rendered with my current setup.  You say you've rendered the scene before so I think you don't have that issue here.
Maybe someone else will come by with some suggestions.  Best wishes,
Rªnce
meltz ( ) posted Thu, 29 September 2011 at 6:49 PM
i can try and redo the scene from scratch. one problem, the light sets i have in the scene is there a way i can save them so i can re use them on the next scene? I would never be able to re do the lights with saving them somehow
Diogenes ( ) posted Thu, 29 September 2011 at 7:34 PM
Yes go to your lights library and add the lights to the library, the same as saving anything else.
Also can you resave the scene file? use a different file name and save it as a pz3 and see if it will work for you.
A HOMELAND FOR POSER FINALLY
bantha ( ) posted Fri, 30 September 2011 at 1:41 AM
Try to use the external render engine, this may help if it's a memory issue.
Lower the bucket size in the rendering options. This may help too.
It could be a memory problem, especially if you don't have a 64-bit OS.
-"Amazing Grace" Hopper
Rance01 ( ) posted Fri, 30 September 2011 at 4:40 AM
Bantha's comment made me think of something else.  Memory issue.  Have you made any changes to your system recently?  You mention you were able to render portions of the scene before, and I assumed the file changed, but did your system change?
Certainly try to Render in Separate Process.  That's a good bit of advice as well.
meltz ( ) posted Fri, 30 September 2011 at 3:06 PM
External render engine? How do i do that?
Rance01 ( ) posted Fri, 30 September 2011 at 4:42 PM
Edit menu, General Preferences, Render tab.  Select Separate Process.
shorterbus ( ) posted Sun, 02 October 2011 at 5:57 AM
I had an experience that may help. I have Poser 8, never had any trouble with it, then got a virus, cleared it all out, but the residual was that my P8 was now very unstable and would crash on renders it used to fly through. After trying everything with no luck, by chance, I right-clicked on the program icon and checked under properties - under compataility - and it was set to be compatiable with Windows Vista. I changed it to Windows 7, and now everything is fine.
meltz ( ) posted Wed, 05 October 2011 at 12:47 PM
Ok i rebuilt the scene from scratch and it still crashes. I also tried the external render but crashes as well.
i attached my settings i am using in firefly. Maybe i have to change something, but i do not want to loose any quility to my image.
This is sad =-(
meltz ( ) posted Wed, 05 October 2011 at 12:48 PM
opps here is the settings
meltz ( ) posted Wed, 05 October 2011 at 1:05 PM
Oh and i have 1.18 GB of free system memory left on my MAC. So i dont think its a memory issue
Rance01 ( ) posted Wed, 05 October 2011 at 2:01 PM
Not sure what else to suggest.  Re-building my scene worked for me.  You might try turning off your lights, one at a time, to see if that is the offending element.  You could probably try lowering your render settings as well.  IR 90, Min Shading rate a little higher.  I wish I could be more help.
Hope you find a solution.
Rªnce
meltz ( ) posted Tue, 11 October 2011 at 1:31 PM
I have tried many things but still crashes. Maybe something im using in this scene is brokin =-(  might just have to try something other then this scene.
meltz ( ) posted Tue, 11 October 2011 at 3:26 PM
This is the report i get when i click report crash.
I dont know what any of it meens but maybe someone here does
Process:         Poser 7 [24950]
Path:            /Applications/Poser 7/Poser 7.app/Contents/MacOS/Poser 7
Identifier:      com.e-frontier.Poser7
Version:         7.0.1.97 (7.0.1.97)
Code Type:       X86 (Native)
Parent Process:  launchd [155]
Interval Since Last Report:          1027794 sec
Crashes Since Last Report:           17
Per-App Interval Since Last Report:  25521 sec
Per-App Crashes Since Last Report:   15
Date/Time:       2011-10-11 16:22:43.986 -0400
OS Version:      Mac OS X 10.5.8 (9L31a)
Report Version:  6
Anonymous UUID:  9A50D921-8E0F-4989-9934-8BF3B11DD6B0
Exception Type:  EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
Crashed Thread:  11
Thread 0:
0   libSystem.B.dylib                 0x9672e2ae semaphore_wait_signal_trap + 10
1   libSystem.B.dylib                 0x967602c6 _pthread_cond_wait + 1267
2   libSystem.B.dylib                 0x967a5539 pthread_cond_wait + 48
3   com.e-frontier.Poser7             0x008eba30 TR_platform_mainThread(int, TR_World**) + 170
4   com.e-frontier.Poser7             0x008ec924 TR_platform_spawnRenderThreads(TR_World*) + 2338
5   com.e-frontier.Poser7             0x008ed3c6 TR_platform_eventLoop + 26
6   com.e-frontier.Poser7             0x0083f413 TR_RiFrameEnd + 3099
7   com.e-frontier.Poser7             0x00249598 PETempestInterface::RenderScene(PEScene*, int, int) + 110
8   com.e-frontier.Poser7             0x00126e72 PEHidLineResolver::Draw() + 1436
9   com.e-frontier.Poser7             0x000fbf91 PECamera::DrawCameraView(bool) + 525
10  com.e-frontier.Poser7             0x0031c7e4 PUIDoc::RedrawDoc(bool) + 6376
11  com.e-frontier.Poser7             0x00306934 PUIDoc::DoCommand(long) + 1752
12  com.e-frontier.Poser7             0x00302be5 PUIDoc::DoRender() + 635
13  com.e-frontier.Poser7             0x00309ec9 PUIDoc::DoCommand(long) + 15469
14  com.e-frontier.Poser7             0x002ec9da wxPoserApp::OnMenu(wxCommandEvent&) + 604
15  com.e-frontier.Poser7             0x00557f73 wxBartender::OnMenu(wxCommandEvent&) + 27
16  libwx_mac.dylib                   0x01708fb8 wxEvtHandler::ProcessEventIfMatches(wxEventTableEntryBase const&, wxEvtHandler*, wxEvent&) + 126
17  libwx_mac.dylib                   0x01709124 wxEventHashTable::HandleEvent(wxEvent&, wxEvtHandler*) + 104
18  libwx_mac.dylib                   0x017095a0 wxEvtHandler::ProcessEvent(wxEvent&) + 128
19  libwx_mac.dylib                   0x0173d379 wxMenuBase::SendEvent(int, int) + 141
20  libwx_mac.dylib                   0x017f8269 wxMacAppEventHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 413
21  com.apple.HIToolbox               0x93d7213d DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1181
22  com.apple.HIToolbox               0x93d7157b SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 405
23  com.apple.HIToolbox               0x93d8decc SendEventToEventTarget + 52
24  com.apple.HIToolbox               0x93dc21e7 SendHICommandEvent(unsigned long, HICommand const*, unsigned long, unsigned long, unsigned char, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 411
25  com.apple.HIToolbox               0x93de8959 SendMenuCommandWithContextAndModifiers + 59
26  com.apple.HIToolbox               0x93de8914 SendMenuItemSelectedEvent + 134
27  com.apple.HIToolbox               0x93de882a FinishMenuSelection(MenuData*, MenuData*, MenuResult*, MenuResult*, unsigned long, unsigned long, unsigned long, unsigned char) + 162
28  com.apple.HIToolbox               0x93dc5494 MenuSelectCore(MenuData*, Point, double, unsigned long, OpaqueMenuRef**, unsigned short*) + 640
29  com.apple.HIToolbox               0x93e54030 MenuSelect + 104
30  libwx_mac.dylib                   0x01829e27 wxMacTopLevelMouseEventHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1483
31  libwx_mac.dylib                   0x017f844a wxMacAppEventHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 894
32  com.apple.HIToolbox               0x93d7213d DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1181
33  com.apple.HIToolbox               0x93d7157b SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 405
34  com.apple.HIToolbox               0x93d8decc SendEventToEventTarget + 52
35  com.apple.HIToolbox               0x93da0603 ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 2579
36  com.apple.HIToolbox               0x93d724f6 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2134
37  com.apple.HIToolbox               0x93d7157b SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 405
38  com.apple.HIToolbox               0x93d8decc SendEventToEventTarget + 52
39  com.e-frontier.Poser7             0x003897fb CEBSwitchboard::ProcessEvent() + 1313
40  com.e-frontier.Poser7             0x00709638 CApplication::Process1Event() + 34
41  com.e-frontier.Poser7             0x002e17b2 PUIApp::DoRun() + 74
42  com.e-frontier.Poser7             0x007095c2 CApplication::HandleForeignExceptions() + 22
43  com.e-frontier.Poser7             0x00709589 CApplication::Run() + 21
44  com.e-frontier.Poser7             0x00330d9d main + 331
45  com.e-frontier.Poser7             0x000024fe _start + 216
46  com.e-frontier.Poser7             0x00002425 start + 41
Thread 1:
0   libSystem.B.dylib                 0x9673544e __semwait_signal + 10
1   libSystem.B.dylib                 0x9675fdcd pthread_cond_wait$UNIX2003 + 73
2   libGLProgrammability.dylib        0x96e2db32 glvmDoWork + 162
3   libSystem.B.dylib                 0x9675f155 _pthread_start + 321
4   libSystem.B.dylib                 0x9675f012 thread_start + 34
Thread 2:
0   libSystem.B.dylib                 0x9672e266 mach_msg_trap + 10
1   libSystem.B.dylib                 0x96735a5c mach_msg + 72
2   com.apple.CoreFoundation          0x979fce7e CFRunLoopRunSpecific + 1790
3   com.apple.CoreFoundation          0x979fdb04 CFRunLoopRun + 84
4   com.apple.DesktopServices         0x91b97d0f TSystemNotificationTask::SystemNotificationTaskProc(void*) + 123
5   ...ple.CoreServices.CarbonCore    0x96b0ffbb PrivateMPEntryPoint + 56
6   libSystem.B.dylib                 0x9675f155 _pthread_start + 321
7   libSystem.B.dylib                 0x9675f012 thread_start + 34
Thread 3:
4   com.apple.DesktopServices         0x91b97e88 TFSEventsNotificationTask::FSEventsNotificationTaskProc(void*) + 216
Thread 4:
2   ...ple.CoreServices.CarbonCore    0x96b11de3 TSWaitOnCondition + 126
3   ...ple.CoreServices.CarbonCore    0x96af0c36 TSWaitOnConditionTimedRelative + 202
4   ...ple.CoreServices.CarbonCore    0x96b11a60 MPWaitOnQueue + 208
5   com.apple.DesktopServices         0x91ba2e6a TNodeSyncTask::SyncTaskProc(void*) + 84
6   ...ple.CoreServices.CarbonCore    0x96b0ffbb PrivateMPEntryPoint + 56
7   libSystem.B.dylib                 0x9675f155 _pthread_start + 321
8   libSystem.B.dylib                 0x9675f012 thread_start + 34
Thread 5:
0   libSystem.B.dylib                 0x9675e9c6 kevent + 10
1   libSystem.B.dylib                 0x9675f155 _pthread_start + 321
2   libSystem.B.dylib                 0x9675f012 thread_start + 34
Thread 6:
0   libSystem.B.dylib                 0x9677d6fa select$DARWIN_EXTSN + 10
Thread 7:
0   libSystem.B.dylib                 0x9672e2c6 semaphore_timedwait_signal_trap + 10
1   libSystem.B.dylib                 0x967602af _pthread_cond_wait + 1244
2   libSystem.B.dylib                 0x96761b33 pthread_cond_timedwait_relative_np + 47
3   com.apple.Foundation              0x95cc0dbc -[NSCondition waitUntilDate:] + 236
4   com.apple.Foundation              0x95cc0bd0 -[NSConditionLock lockWhenCondition:beforeDate:] + 144
5   com.apple.Foundation              0x95cc0b35 -[NSConditionLock lockWhenCondition:] + 69
6   com.apple.AppKit                  0x91ff76e8 -[NSUIHeartBeat _heartBeatThread:] + 753
7   com.apple.Foundation              0x95c7adfd -[NSThread main] + 45
8   com.apple.Foundation              0x95c7a9a4 NSThread__main + 308
9   libSystem.B.dylib                 0x9675f155 _pthread_start + 321
10  libSystem.B.dylib                 0x9675f012 thread_start + 34
Thread 8:
4   com.apple.DesktopServices         0x91bd6969 TQueryTask::QueryTaskProc(void*) + 95
Thread 9:
Thread 10:
3   ...ple.CoreServices.CarbonCore    0x96af0c62 TSWaitOnConditionTimedRelative + 246
5   com.apple.DesktopServices         0x91ba4db4 TFolderSizeTask::FolderSizeTaskProc(void*) + 104
Thread 11 Crashed:
0   com.e-frontier.Poser7             0x008b82fc TR_render_rasterizePatch(TR_World*, TR_PrivateGlobals*, int) + 114
1   com.e-frontier.Poser7             0x008bbf36 TR_render_submitObject(TR_World*, int) + 1660
2   com.e-frontier.Poser7             0x008bcd0b TR_render_handleNullEvent(TR_World*, int) + 3227
3   com.e-frontier.Poser7             0x008bd127 TR_render_thread(void*) + 41
4   com.e-frontier.Poser7             0x00b3ede6 TR_RenderThread::DoBegin() + 20
5   com.e-frontier.Poser7             0x00862ac8 sThreadStarter(void*) + 136
Thread 12:
0   libSystem.B.dylib                 0x9672e386 mach_wait_until + 10
1   libSystem.B.dylib                 0x967a53ad nanosleep + 314
2   libSystem.B.dylib                 0x967a526d usleep + 61
3   com.e-frontier.Poser7             0x00b3f02b TR_TimerThread::DoRepeatedly() + 21
4   com.e-frontier.Poser7             0x00862ada sThreadStarter(void*) + 154
5   libSystem.B.dylib                 0x9675f155 _pthread_start + 321
6   libSystem.B.dylib                 0x9675f012 thread_start + 34
Thread 11 crashed with X86 Thread State (32-bit):
  eax: 0x00000001  ebx: 0x00000000  ecx: 0x345bdb10  edx: 0x00000000
  edi: 0x2cbf2000  esi: 0x4b57f520  ebp: 0xb067cd48  esp: 0xb067c670
   ss: 0x0000001f  efl: 0x00010202  eip: 0x008b82fc   cs: 0x00000017
   ds: 0x0000001f   es: 0x0000001f   fs: 0x0000001f   gs: 0x00000037
  cr2: 0x00000000
Binary Images:
    0x1000 -   0xcc7fef +com.e-frontier.Poser7 7.0.1.97 (7.0.1.97) /Applications/Poser 7/Poser 7.app/Contents/MacOS/Poser 7
 0x1682000 -  0x16ccffc +Clothlib.dylib ??? (???) /Applications/Poser 7/Poser 7.app/Contents/Frameworks/Clothlib.dylib
 0x16e5000 -  0x19b7fcb +libwx_mac.dylib ??? (???) <571edc72a6d6472da047da04cac53cb9> /Applications/Poser 7/Poser 7.app/Contents/Frameworks/libwx_mac.dylib
 0x1c91000 -  0x1d8efc2 +libfreeimage.dylib ??? (???) /Applications/Poser 7/Poser 7.app/Contents/Frameworks/libfreeimage.dylib
 0x1dce000 -  0x1eb1fe3 +org.python.python 2.4a0 (2.2) /Library/Frameworks/Python.framework/Versions/2.4/Python
 0x20cc000 -  0x2615fe7 +Cg ??? (???) /Applications/Poser 7/Poser 7.app/Contents/Frameworks/Cg.framework/Cg
0x161dd000 - 0x161defe1  com.apple.textencoding.unicode 2.2 (2.2) <6566f38ef8ee61fab9aaecfb6a81f208> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
0x1843f000 - 0x18449ffe  com.apple.URLMount 3.1.1 (3.1.1) /System/Library/PrivateFrameworks/URLMount.framework/URLMount
0x18544000 - 0x18545ff3  ATSHI.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/ATSHI.dylib
0x18561000 - 0x18566ff3  libCGXCoreImage.A.dylib ??? (???) <4199fa0c7dd9592abf465b20feec52f9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
0x194b7000 - 0x197b0ff3  com.apple.RawCamera.bundle 2.3.0 (505) <1c7cea30ffe2b4de98ced6518df1e54b> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x1a8e1000 - 0x1a908ffc +com.e-frontier.poserplugin.File Format 3DS ??? () /Applications/Poser 7/Poser 7.app/Contents/PlugIns/File Format 3DS.arp/Contents/MacOS/File Format 3DS
0x1a922000 - 0x1a943fff +com.e-frontier.poserplugin.File Format DXF ??? () /Applications/Poser 7/Poser 7.app/Contents/PlugIns/File Format DXF.arp/Contents/MacOS/File Format DXF
0x1a95a000 - 0x1a985fe4 +com.e-frontier.poserplugin.File Format LWO ??? () /Applications/Poser 7/Poser 7.app/Contents/PlugIns/File Format LWO.arp/Contents/MacOS/File Format LWO
0x1a9a3000 - 0x1a9cbfff +com.e-frontier.poserplugin.File Format VRML ??? () /Applications/Poser 7/Poser 7.app/Contents/PlugIns/File Format VRML.arp/Contents/MacOS/File Format VRML
0x1a9e6000 - 0x1aa0cff4 +com.e-frontier.poserplugin.File Format Wavefront ??? () /Applications/Poser 7/Poser 7.app/Contents/PlugIns/File Format Wavefront.arp/Contents/MacOS/File Format Wavefront
0x1ab5f000 - 0x1ab7bff7  GLRendererFloat ??? (???) <927b7d5ce6a7c21fdc761f6f29cdf4ee> /System/Library/Frameworks/OpenGL.framework/Versions/A/Resources/GLRendererFloat.bundle/GLRendererFloat
0x1ad0d000 - 0x1ae92fe3  GLEngine ??? (???) <3bd4729832411ff31de5bb9d97e3718d> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
0x1afdc000 - 0x1afdffff +strop.so ??? (???) /Library/Frameworks/Python.framework/Versions/2.4/lib/python2.4/lib-dynload/strop.so
0x1b800000 - 0x1badeff1  com.apple.ATIRadeonX2000GLDriver 1.5.48 (5.4.8) <0858896931bc8cdd84f736ed21e23738> /System/Library/Extensions/ATIRadeonX2000GLDriver.bundle/Contents/MacOS/ATIRadeonX2000GLDriver
0x1cbda000 - 0x1cbebfff +_numpy.so ??? (???) /Applications/Poser 7/Poser 7.app/Contents/PythonExtensions/Numeric/_numpy.so
0x8fe00000 - 0x8fe2db43  dyld 97.1 (???) <458eed38a009e5658a79579e7bc26603> /usr/lib/dyld
0x90015000 - 0x900a2ff7  com.apple.framework.IOKit 1.5.2 (???) <7a3cc24f78f93931731203854ae0d891> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x900a3000 - 0x90461fea  libLAPACK.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x90462000 - 0x904e1ff5  com.apple.SearchKit 1.2.2 (1.2.2) <3b5f3ab6a363a4d8a2bbbf74213ab0e5> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x904e2000 - 0x904ffff7  com.apple.QuickLookFramework 1.3.1 (170.9) /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
0x90500000 - 0x906f8fff  com.apple.JavaScriptCore 5533.19 (5533.19.1) /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x9181a000 - 0x9181aff8  com.apple.ApplicationServices 34 (34) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x9181b000 - 0x91864fef  com.apple.Metadata 10.5.8 (398.26) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framework/Versions/A/Metadata
0x918aa000 - 0x918c8fff  libresolv.9.dylib ??? (???) /usr/lib/libresolv.9.dylib
0x918c9000 - 0x918e5ff3  com.apple.CoreVideo 1.6.1 (48.6) <186cb311c17ea8714e918273c86d3c13> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x918e6000 - 0x91920fe7  com.apple.coreui 1.2 (62) /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x91921000 - 0x919aeff7  com.apple.LaunchServices 292 (292) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x919af000 - 0x919d8fff  libcups.2.dylib ??? (???) <2b0ab6b9fa1957ee940835d0cfd42894> /usr/lib/libcups.2.dylib
0x919d9000 - 0x91a4bfff  com.apple.PDFKit 2.1.2 (2.1.2) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versions/A/PDFKit
0x91a4c000 - 0x91a9afe3  com.apple.AppleVAFramework 4.1.17 (4.1.17) /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
0x91a9b000 - 0x91a9bffe  com.apple.quartzframework 1.5 (1.5) <49afd7e7e3b2cad89cfaf2ac8c67c8a4> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
0x91a9c000 - 0x91aa3fff  com.apple.agl 3.0.9 (AGL-3.0.9) <2f39c480cfcee9358a23d61b20a6aa56> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
0x91b96000 - 0x91c20ff7  com.apple.DesktopServices 1.4.9 (1.4.9) /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x91c21000 - 0x91c28fe9  libgcc_s.1.dylib ??? (???) <28a7cbc3a5ca2982d124668306f422d9> /usr/lib/libgcc_s.1.dylib
0x91c29000 - 0x91c85ff7  com.apple.htmlrendering 68 (1.1.3) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework/Versions/A/HTMLRendering
0x91c86000 - 0x91cb1fe7  libauto.dylib ??? (???) <2072d673706bbe463ed2426af57a28d7> /usr/lib/libauto.dylib
0x91cb2000 - 0x91cb2ffe  com.apple.MonitorPanelFramework 1.2.0 (1.2.0) <1bce4a22b6a5cc7055d0938ddad269b2> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
0x91e43000 - 0x91f2bff3  com.apple.CoreData 100.2 (186.2) <44df326fea0236718f5ed64084e82270> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x91f51000 - 0x9274ffef  com.apple.AppKit 6.5.9 (949.54) <4df5d2e2271175452103f789b4f4d8a8> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x927b7000 - 0x927c3ff9  com.apple.helpdata 1.0.1 (14.2) /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
0x927c4000 - 0x92980ff3  com.apple.QuartzComposer 2.1 (106.13) <40f034e8c8fd31c9081f5283dcf22b78> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framework/Versions/A/QuartzComposer
0x92981000 - 0x92983ff5  libRadiance.dylib ??? (???) <276f13ab6429e05b093a8dda251e3b53> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
0x92984000 - 0x92a8bff7  com.apple.WebKit 5533.19 (5533.19.4) <9299024ba5d2d796781e6d7312fae16a> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x92a8c000 - 0x92abbfe3  com.apple.AE 402.3 (402.3) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x92abc000 - 0x92bf5ff7  libicucore.A.dylib ??? (???) /usr/lib/libicucore.A.dylib
0x92bf6000 - 0x92c53ffb  libstdc++.6.dylib ??? (???) <6106b1f2b0b303b06ae476253dbb5f3f> /usr/lib/libstdc++.6.dylib
0x92c54000 - 0x92d34fff  libobjc.A.dylib ??? (???) <7b92613fdf804fd9a0a3733a0674c30b> /usr/lib/libobjc.A.dylib
0x92d35000 - 0x92dc8ff3  com.apple.ApplicationServices.ATS 3.8 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x92dc9000 - 0x92dc9ff8  com.apple.Cocoa 6.5 (???) /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
0x92e05000 - 0x938fffff  com.apple.WebCore 5533.19 (5533.19.4) <9b91bb00c553ec746fdbe51abca306af> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x939ef000 - 0x93a6cfeb  com.apple.audio.CoreAudio 3.1.2 (3.1.2) <782a08c44be4698597f4bbd79cac21c6> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x93a6d000 - 0x93b34ff2  com.apple.vImage 3.0 (3.0) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x93b35000 - 0x93c7dff7  com.apple.ImageIO.framework 2.0.7 (2.0.7) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x93c7e000 - 0x93d25fec  com.apple.CFNetwork 438.16 (438.16) /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x93d26000 - 0x93d28fff  com.apple.securityhi 3.0 (30817) <020419ad33b8638b174e1a472728a894> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x93d29000 - 0x93d69fef  com.apple.CoreMedia 0.484.2 (484.2) <81221976abdc19f30723c81c5669bbc9> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
0x93d6a000 - 0x94072fe7  com.apple.HIToolbox 1.5.6 (???) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x94073000 - 0x940c4ff7  com.apple.HIServices 1.7.1 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x940c5000 - 0x940cafff  com.apple.CommonPanels 1.2.4 (85) <3b64ef0de184d09c6f99a1a7e77e42be> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x940fe000 - 0x940feffd  com.apple.Accelerate 1.4.2 (Accelerate 1.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x940ff000 - 0x9410afe7  libCSync.A.dylib ??? (???) <06652e36188190ec04d294f49c68f28a> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x9410b000 - 0x94133ff7  com.apple.shortcut 1.0.1 (1.0) <131202e7766e327d02d55c0f5fc44ad7> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
0x94134000 - 0x94134fff  com.apple.Carbon 136 (136) /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x94141000 - 0x94172ffb  com.apple.quartzfilters 1.5.0 (1.5.0) <01090d7204c55b32a6a11199fa0d2e2b> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework/Versions/A/QuartzFilters
0x94176000 - 0x9417afff  libGIF.dylib ??? (???) <36f7b0255a81d97c7b360c3b11b4e462> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x9417e000 - 0x94225feb  com.apple.QD 3.11.57 (???) <35f058678972d42b88ebdf652df79956> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x94226000 - 0x942a3fef  libvMisc.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x942f6000 - 0x94350ff7  com.apple.CoreText 2.0.5 (???) <5483518a613464d043455ac661a9dcbe> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x94351000 - 0x94351ffd  com.apple.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x94352000 - 0x94352ffc  com.apple.audio.units.AudioUnit 1.5 (1.5) /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x94353000 - 0x9440efe3  com.apple.CoreServices.OSServices 228.1 (228.1) <76fdc146b4d9937f9c5cbaa1512e0023> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x9440f000 - 0x94425fff  com.apple.DictionaryServices 1.0.0 (1.0.0) <7e9ff586b5c9d02b09e2a5527d98524f> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x9458a000 - 0x9458ffff  com.apple.DisplayServicesFW 2.0.2 (2.0.2) /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
0x94590000 - 0x94594fff  libmathCommon.A.dylib ??? (???) /usr/lib/system/libmathCommon.A.dylib
0x94595000 - 0x94645fff  edu.mit.Kerberos 6.0.14 (6.0.14) <673f107cdae80c084774a27bc7bc46c1> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x94646000 - 0x94685fef  libTIFF.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
0x94686000 - 0x94857ff3  com.apple.security 5.0.6 (37592) <0b25e1e4cc34431630f01edb3fdf54d1> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x94858000 - 0x94859ffc  libffi.dylib ??? (???) <596e0dbf626b211741cecaa9698f271b> /usr/lib/libffi.dylib
0x9485a000 - 0x94887feb  libvDSP.dylib ??? (???) <2ee4eb005babc90eaa352b33eb09226e> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvDSP.dylib
0x94888000 - 0x948c9fe7  libRIP.A.dylib ??? (???) <378694b494a02de1b0c812da572579d2> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x948ca000 - 0x948d4feb  com.apple.audio.SoundManager 3.9.2 (3.9.2) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/Versions/A/CarbonSound
0x948d5000 - 0x948d8fff  com.apple.help 1.1 (36) <175489f8adf287b3ebd259362b0292c0> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x948d9000 - 0x948f7ff3  com.apple.DirectoryService.Framework 3.5.7 (3.5.7) /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x948f8000 - 0x94951ff7  libGLU.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x9496a000 - 0x94d07fef  com.apple.QuartzCore 1.5.8 (1.5.8) /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x94d08000 - 0x94d20fff  com.apple.openscripting 1.2.8 (???) <572c7452d7e740e8948a5ad07a99602b> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x94d21000 - 0x95131fef  libBLAS.dylib ??? (???) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x95181000 - 0x951b8fff  com.apple.SystemConfiguration 1.9.2 (1.9.2) <8b26ebf26a009a098484f1ed01ec499c> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x951b9000 - 0x95575ff4  com.apple.VideoToolbox 0.484.2 (484.2) <46c37a5fead4e4f58501f15a641ff476> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x9558a000 - 0x955aefff  libxslt.1.dylib ??? (???) <0a9778d6368ae668826f446878deb99b> /usr/lib/libxslt.1.dylib
0x955af000 - 0x955ceffa  libJPEG.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x955cf000 - 0x95c6ffef  com.apple.CoreGraphics 1.409.7 (???) <7b65edcce394f39b6a1954d5e30bc34c> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x95c70000 - 0x95eecfe7  com.apple.Foundation 6.5.9 (677.26) /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x95eed000 - 0x95fceff7  libxml2.2.dylib ??? (???) /usr/lib/libxml2.2.dylib
0x95fcf000 - 0x95fdcfe7  com.apple.opengl 1.5.10 (1.5.10) <5a2813f80c9441170cc1ab8a3dac5038> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x9627b000 - 0x96287ffe  libGL.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x96288000 - 0x962a3ff3  libPng.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x962a4000 - 0x963f6ff3  com.apple.audio.toolbox.AudioToolbox 1.5.3 (1.5.3) /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x963f7000 - 0x96722ff6  com.apple.QuickTime 7.6.9 (1680.9) <024f122335016a54f8e59ddb4c79901d> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
0x96723000 - 0x9672cfff  com.apple.speech.recognition.framework 3.7.24 (3.7.24) <6a6518b392d3d41ace3dcea69d6809d9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x9672d000 - 0x96894ff3  libSystem.B.dylib ??? (???) /usr/lib/libSystem.B.dylib
0x96895000 - 0x96947ffb  libcrypto.0.9.7.dylib ??? (???) /usr/lib/libcrypto.0.9.7.dylib
0x969b6000 - 0x96a81fef  com.apple.ColorSync 4.5.3 (4.5.3) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x96a82000 - 0x96a82ffb  com.apple.installserver.framework 1.0 (8) /System/Library/PrivateFrameworks/InstallServer.framework/Versions/A/InstallServer
0x96a83000 - 0x96ac1fff  libGLImage.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
0x96ac7000 - 0x96da1ff3  com.apple.CoreServices.CarbonCore 786.16 (786.16) <60b518e4ad02b91826240199a6311286> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framework/Versions/A/CarbonCore
0x96da2000 - 0x96db2ffc  com.apple.LangAnalysis 1.6.5 (1.6.5) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x96db3000 - 0x96db9fff  com.apple.print.framework.Print 218.0.3 (220.2) <5b7f4ef7c2df36aff9605377775781e4> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x96e06000 - 0x972d7fbe  libGLProgrammability.dylib ??? (???) <7f18294a7bd0b6afe4319f29187fc70d> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dylib
0x973a2000 - 0x973b2fff  com.apple.speech.synthesis.framework 3.7.1 (3.7.1) <06d8fc0307314f8ffc16f206ad3dbf44> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x973b3000 - 0x973baff7  libCGATS.A.dylib ??? (???) <29154398dbefc2a1a97715e5af1e3552> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGATS.A.dylib
0x973bb000 - 0x9744efff  com.apple.ink.framework 101.3 (86) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x9744f000 - 0x9749efff  com.apple.QuickLookUIFramework 1.3.1 (170.9) /System/Library/PrivateFrameworks/QuickLookUI.framework/Versions/A/QuickLookUI
0x9749f000 - 0x974b4ffb  com.apple.ImageCapture 5.0.2 (5.0.2) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x974f8000 - 0x9753afef  com.apple.NavigationServices 3.5.2 (163) <91844980804067b07a0b6124310d3f31> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.framework/Versions/A/NavigationServices
0x97540000 - 0x97548fff  com.apple.DiskArbitration 2.2.1 (2.2.1) <42908e7ecc17a83cec4afef2850ec79e> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x97549000 - 0x97681fe7  com.apple.imageKit 1.0.2 (1.0) <00d03cf7f26e1b6023efdc4bd15dd52e> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Versions/A/ImageKit
0x9776f000 - 0x977baff7  com.apple.CoreMediaIOServices 130.0 (935) /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOServices
0x977cb000 - 0x97915feb  com.apple.QTKit 7.6.9 (1680.9) /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
0x97916000 - 0x97989fff  com.apple.iLifeMediaBrowser 2.1.5 (368) <3026150475335424dd1532739ded6fb0> /System/Library/PrivateFrameworks/iLifeMediaBrowser.framework/Versions/A/iLifeMediaBrowser
0x9798a000 - 0x97abdfe7  com.apple.CoreFoundation 6.5.7 (476.19) /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x97abe000 - 0x97b38ff8  com.apple.print.framework.PrintCore 5.5.4 (245.6) <03d0585059c20cb0bde5e000438c49e1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore.framework/Versions/A/PrintCore
0x97b39000 - 0x97b39ffd  com.apple.Accelerate.vecLib 3.4.2 (vecLib 3.4.2) /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x97b47000 - 0x97c3bff4  libiconv.2.dylib ??? (???) <3f183527811098bb7332f67a1f902bfd> /usr/lib/libiconv.2.dylib
0x97c3c000 - 0x97c43ffe  libbsm.dylib ??? (???) <5582985a86ea36504cca31788bccf963> /usr/lib/libbsm.dylib
0x97c44000 - 0x97c52ffd  libz.1.dylib ??? (???) <545ca09467025f77131cfac09d8b9375> /usr/lib/libz.1.dylib
0x97c53000 - 0x97cdaff7  libsqlite3.0.dylib ??? (???) <3334ea5af7a911637413334154bb4100> /usr/lib/libsqlite3.0.dylib
0x97cdb000 - 0x97ceaffe  com.apple.DSObjCWrappers.Framework 1.2.1 (1.2.1) <43c5b91223501f917392f59fbf9d7ace> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
0x97ceb000 - 0x97cebffa  com.apple.CoreServices 32 (32) <2760719f7a81e8c2bdfd15b0939abc29> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x97cec000 - 0x97e70fef  com.apple.MediaToolbox 0.484.2 (484.2) <32bf3254fafd942cf8f2c813960217fd> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
0xeab00000 - 0xeab0ffff  libConverter.dylib ??? (???) /System/Library/Printers/Libraries/libConverter.dylib
0xfffe8000 - 0xfffebfff  libobjc.A.dylib ??? (???) /usr/lib/libobjc.A.dylib
0xffff0000 - 0xffff1780  libSystem.B.dylib ??? (???) /usr/lib/libSystem.B.dylib
bantha ( ) posted Tue, 11 October 2011 at 4:11 PM · edited Tue, 11 October 2011 at 4:12 PM
You could try a smaller bucket size, 32 or 16. This won't affect the quality.
meltz ( ) posted Tue, 11 October 2011 at 7:29 PM
Quote - You could try a smaller bucket size, 32 or 16. This won't affect the quality.
Ok ill try that tommorow, and update if it works!
KimberlyC ( ) posted Tue, 11 October 2011 at 7:44 PM
I have that problem quite often with 8. normally like Bantha said.. I lower my bucket size. Renders slower but if you want that render it maybe worth the wait. :)
_____________________
.::That which does not kill us makes us stronger::.
-- Friedrich Nietzsche
