Fri, Nov 29, 6:14 PM CST
Vue F.A.Q (Last Updated: 2024 Nov 29 1:34 pm)
Subject: Poser import problem since installing Poser Pro 2012
Jcleaver ( ) posted Mon, 03 October 2011 at 6:33 PM · edited Thu, 28 November 2024 at 7:28 AM
Any ideas on what i can do to get Poser imports to work again?  Before I installed Poser Pro 2012, I had Poser pro 2010 and the imports orked fine.  Now, I get an error saying that there was a SDK error.  This is for PZ3s that hadn't even been opened by Poser 2012 yet.  I still have Poser Pro 2010 installed, but loading into there and resaving doesn't help.
After getting these errors, I did try to update Vue to say Poser was in my Poser 2012 directory, and when I try to import now Vue crashes.
I am using Vue 9 Infinite.  As far as i can tell, there have been no official updates for this.  I do see 2 beta updates, but neither of those address Poser imports.
Dale B ( ) posted Mon, 03 October 2011 at 7:17 PM
Vue 9 x doesn't support the P9/2012 sdk, and there are enough changes that the 2010 sdks simply will not work with it. Probably it will be for Vue 10 to be compatible (and maybe not right away; we don't know when they got the 2012 sdk to e-on. It may take an update or two for it to all be in there). Your best bet is to tell Vue to use 2010, and make sure you have to runtime pointing at the right iteration of Poser; otherwise, Vue will freak out demanding every single file be found....and if it runs into 2012, crashbangboom......
Jcleaver ( ) posted Mon, 03 October 2011 at 7:38 PM
Unfortunately, i did have Vue using Poser 2010, and my runtime in the 2010 runtime.  I had figured that Vue would not recognize 2012, so i didn't change anything with Vue until I ran into the sdk errors after installing Poser 2012.  Before that, Poser import worked very well.  Something in the Poser 2012 install seems to have changed something but I can't figure out what.
thefixer ( ) posted Tue, 04 October 2011 at 12:45 AM
I use PP2012 now and I can import pz3's fine..
I have Vue 9 Infinite and have it set to look at Poser 7 using the March 2010 sdk.
No problem here..
Injustice will be avenged.
Cofiwch Dryweryn.
Jcleaver ( ) posted Tue, 04 October 2011 at 7:36 AM
I do not have Poser 7.  It worked fine looking at Poser 2010 before I installed 2012.  It doesn't work now.
I guess what I am looking for is a way to get it to work for me again.  i know it works for others, and it used to work for me.
(I know i sound a little grumpy, haven't had my coffee yet!)
thefixer ( ) posted Tue, 04 October 2011 at 11:52 AM
So I presume you still have it looking at PP2010 yes??
If so it should still work using that, it really doesn't matter for the most part, it's only really for finding the textures, the sdk is what is the critical element, what is that set to?
Cofiwch Dryweryn.
Jcleaver ( ) posted Tue, 04 October 2011 at 7:35 PM
Yes, it is looking at 2010, and using the march SDK.
thefixer ( ) posted Wed, 05 October 2011 at 1:08 AM
Hmm, then I am at a loss to suggest anything else, except maybe running the uncompress script inside Poser because Vue doesn't like compressed files..
Cofiwch Dryweryn.
Jcleaver ( ) posted Wed, 05 October 2011 at 6:17 AM
I have got it working now.   I installed Poser 7 and pointed to it and imports now work again.  Thanks!
sunfish ( ) posted Sat, 08 October 2011 at 12:28 PM
Your tip is golden, thefixer. My Vue was configured to Poser 8, and Vue did not know the Poser 9 file. After I configured on Poser 7, everything is fine again. Crazy!
thefixer ( ) posted Sat, 08 October 2011 at 12:50 PM
Yep crazy, isn't that why we all love Vue so much...LOLOLOL
Cofiwch Dryweryn.
sunfish ( ) posted Sat, 08 October 2011 at 8:54 PM
Quote - Yep crazy, isn't that why we all love Vue so much...LOLOLOL
That's what I think deep in my soul for a loooong time now :-)) But we never give up!
Thanks again for this great hint, thefixer. I felt so lost ...
Darboshanski ( ) posted Tue, 15 November 2011 at 10:32 AM
Well this didn't work for me. I installed Poser 7 back again, pointed vue 2012 to it using the March 2010 SDK, restarted vue and I can't import a damn thing all vue does is look for everything. It's like poser isn't even installed so I go poser 7 knowing what the problem is cuz I've had this happen before and add all the external runtime folders.
Now here is the most interesting part. Each I open Vue it still says it can't find anything poser so I go to Poser 7, open the program and all my external runtime folders I added are now gone. And instead the of folder at the top saying poser 7 it now says poser 8 and I didn't add any poser 8 folders to Poser 7. So I am at a total loss nothing I try, no poser version I try will import into vue now. Since Poser 7 will not hold the external runtime folders, which I find odd and never had this happen before, Vue can't find anything. So I don't know what to do now at all.
My Facebook Page
thefixer ( ) posted Tue, 15 November 2011 at 12:16 PM
Hey there, what system are you running Windows7, UAC on/off??
Some other windows version?
Cofiwch Dryweryn.
Darboshanski ( ) posted Tue, 15 November 2011 at 4:48 PM
I am running windows 7 64-bit with the UAC off. It crazy because I had Poser 7 installed before. I am just wondering if I need re-install Vue 9 and then point it to Poser 7. Right now both Vue 8 and 9 are acting as if poser is not even installed which is strange because just last night everything was running like a champ.
I think it's all my fault I had Vue 8 and 9 pointed at Poser Pro 2010 with Feb2010 SDK and all was fine. I was having some clothing issues with figures when importing .PZ3 files into Vue 9. So I figured I'd try installing Poser 7 and pointing vue 9 to that with the Mar2010 SDK and that is when all the problems began. Vue can't find anything poser now. I am just wondering if I should un-install Vue 9 and start fresh.
My Facebook Page
thefixer ( ) posted Tue, 15 November 2011 at 5:01 PM
Do you have a restore point to try?
Take it back to before you re-installed P7, see if that works..
No idea why it's acting that way for you..
Cofiwch Dryweryn.
Darboshanski ( ) posted Tue, 15 November 2011 at 6:40 PM
restored still having the same problem I don't understand why now. I am going to just un-install it all and start all over again. Thanks Gwyn for your help!!
My Facebook Page
Darboshanski ( ) posted Tue, 15 November 2011 at 7:40 PM
Oh I wanted to ask Gwyn did Poser 7 have all the external runtimes linked to it? Or did you just have the base program installed and just pointed Vue 9 to it?
Thanks
My Facebook Page
thefixer ( ) posted Wed, 16 November 2011 at 1:11 AM
No I have Poser 6, 7 and 8 fully installed at the time, no external runtimes,I use sub folders.
I've got PP2012 and Vue 10 now though, but the other versions of poser are still there. TBH I actually still use my Poser 6 runtime, all new stuff I buy still goes in that runtime..
Cofiwch Dryweryn.
Darboshanski ( ) posted Fri, 18 November 2011 at 8:33 AM
All is well again imports are now working from both Poser Pro 2010 and 2012 within Vue 8 and 9. I am holding off getting Vue 10 until I see more from everyday users and what their opinions are.
My Facebook Page
thefixer ( ) posted Fri, 18 November 2011 at 8:49 AM
Glad to hear it my friend..I'm finding version 10 ok at the minute, some bugs of course but nothing I can't work around, but we're all used to that with Vue eh..!
roflmao..
Cofiwch Dryweryn.
Darboshanski ( ) posted Fri, 18 November 2011 at 9:06 AM
Yes Vue is Vue to have it work the way we want would be shocking and also suspicious hehehe!
My Facebook Page
