Wed, Jan 8, 12:00 AM CST
Subject: A mini tut... Creating The Ring ......
ThunderStone ( ) posted Sun, 09 October 2011 at 6:22 PM · edited Tue, 07 January 2025 at 11:59 PM
Creating the Ring Object:
Select the Torus from the Create Menu:
To make it into a ring like structure, follow these settings as seen in the image 1. Experiment.
OS: Windows 11 64-bit
Poser: Poser 11.3 ...... Units: inches or meters depends on mood
Bryce: Bryce Pro 7.1.074
Image Editing: Corel Paintshop Pro
Renderer: Superfly, Firefly
9/11/2001: Never forget...
Smiles are contagious... Pass it on!
Today is the tomorrow you worried about yesterday
ThunderStone ( ) posted Sun, 09 October 2011 at 7:53 PM · edited Sun, 09 October 2011 at 7:55 PM
Image 1
Image 1 shows the setting for the ring...
ThunderStone ( ) posted Sun, 09 October 2011 at 7:56 PM · edited Sun, 09 October 2011 at 7:59 PM
Image 2
Image 2 shows the adjustment to the torus to make it into a "ring".
Set the inner diameter of the torus to between 200 and 100
ThunderStone ( ) posted Sun, 09 October 2011 at 8:05 PM · edited Sun, 09 October 2011 at 8:07 PM
Image 3
Image 3 shows the setting for the cylinder (the engraving object)
Creating the Engraving Object
Select the Cylinder form the Create Menu:
To make it into an engraving object, follow these settings as seen in the image 3. Adjust to fix in the torus.
Now select both the torus and the cylinder and combine them.
ThunderStone ( ) posted Sun, 09 October 2011 at 8:32 PM
Image 4
Image 4 shows the DTE setting for the mat for the cylinder
Select the cylinder on the main stage, click on the small "M" to go to the mat editor. Place a button in the diffuse setting. Click on the P button to go into the DTE for the image texture editor. See the image 4 for the settings.
Go here for the image and save the image (in the first post) to your desktop.
ThunderStone ( ) posted Sun, 09 October 2011 at 8:45 PM
Image 5
Image 5 shows the gold mat used for both the torus and the cylinder
When finished, click OK and exit the editor.
Select the torus and enter the Mat editor by clicking on the "M" . Bring up the Material collections and look for Metal. See image 5 for further details.
ThunderStone ( ) posted Sun, 09 October 2011 at 8:53 PM
Image 6
Image 6 shows the Mat setting for the cylinder.
ThunderStone ( ) posted Sun, 09 October 2011 at 8:54 PM
Image 7
Image 7 shows the gold diffuse color setting for the cylinder
ThunderStone ( ) posted Sun, 09 October 2011 at 9:14 PM
After you finish matting the ring, do a test render to see how it looks. You might have to tweak it a bit to get it to look just right for yourself... Here's a sample of what it might look like for me. Larger view is in my gallery.
The Ring
TheBryster ( ) posted Mon, 10 October 2011 at 11:10 AM
Forum Moderator
Way cool!
ThunderStone ( ) posted Mon, 10 October 2011 at 11:40 AM
Thank you, Bryster!
skiwillgee ( ) posted Mon, 10 October 2011 at 3:07 PM
!!!!!!   Outstanding tutorial  !!!!!!!   .... willie bows to the lady.
ThunderStone ( ) posted Mon, 10 October 2011 at 6:30 PM
Thanks, Willie! 😊
Quest ( ) posted Mon, 10 October 2011 at 7:25 PM
Nicely done ThunderStone. Say, that interface doesn't look all that mush different than Bryce 5.5.
ThunderStone ( ) posted Mon, 10 October 2011 at 7:50 PM
Quest: in a sense, no... but there is a difference in the mat editor.. the dirt shader is hidden in there... LOL
Quest ( ) posted Mon, 10 October 2011 at 9:33 PM
LOL...I knew there would be a catch somewhere...hidden shaders and stuff...j/k, I'm sure noobies would have no trouble getting into the know in minimal time. Anyway, nice, concise and to the point mini tut on the ring.
ThunderStone ( ) posted Mon, 10 October 2011 at 9:49 PM
Thank you, Quest! 😊
