Tue, Jan 14, 5:17 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 14 12:25 pm)
Subject: Why my AO so ugly? How to make it better?
triangle2010 ( ) posted Tue, 11 October 2011 at 5:24 PM · edited Tue, 14 January 2025 at 5:08 PM
I use the AO node, comes out like this. It dosen't look like shadow, just like some dirt.What I did wrong? I look in here seems no one got this problem.
I am using poserpro.
:b_sad:
RobynsVeil ( ) posted Tue, 11 October 2011 at 5:36 PM
Lights? ray-traced? IDL?
Metaphor of Chooks
bagginsbill ( ) posted Tue, 11 October 2011 at 5:56 PM
Increase the irradiance cache render setting.
triangle2010 ( ) posted Tue, 11 October 2011 at 5:57 PM
I used 3 ininite lights, 1 with shadow map and other 2 don't have shadow. I am using poser pro the version b4 P8, don't got IDL. I also try IBL in other test and still got this ugly AO
It dosen't look like shadow but looks like dust on table that haven't clean for 3 years:b_sweat:
triangle2010 ( ) posted Tue, 11 October 2011 at 5:59 PM
Quote - Increase the irradiance cache render setting.
increase to how many? I can't remember this one but I've try around 80.:sad:
bagginsbill ( ) posted Tue, 11 October 2011 at 6:25 PM
When asking for help, always state which Poser version and which SR.
This looks like Poser 8 without the updates. If so you are running buggy code. Stay up to date. Poser 8 is at SR3, SR3.1 if you're German.
triangle2010 ( ) posted Tue, 11 October 2011 at 9:21 PM
Quote - When asking for help, always state which Poser version and which SR.
Thanks BB, I say in posts b4, I am using poserpro, that is the version after P7 and before P8.
But I can't remember those numbers (something point something....). :b_uncertain:
I think I need to findout if it needs those SR.
Thankks again.  :b_smile:
bagginsbill ( ) posted Tue, 11 October 2011 at 10:06 PM
Sorry I missed that. Any words near giant emoticons become invisible to me. I just see the face.
icprncss2 ( ) posted Wed, 12 October 2011 at 12:13 PM
The original Poser Pro has irradiance cache settings in the render settings.  As BB, stated, increase it.
Raytraced shadows or deep shadow maps?
Also try lowering your minimum shading rate.
MistyLaraCarrara ( ) posted Wed, 12 October 2011 at 1:27 PM
it looks the AO node is attached to the object surface. :huh:
i thought it was supposed to attach to the light?
and the light type should be set to IBL, so the light knows what direction to make the shadow fall?
bagginsbill ( ) posted Wed, 12 October 2011 at 1:51 PM
The AO node is for surfaces, MLP. I don't feel like writing why you'd use it. I'm assuming for the sake of simplicity that the OP is doing this for a reason. He didn't ask for advice on when to use the AO node.
But you're right, the better choice if you want AO is to just enable it on IBL lights.
