Tue, Jan 21, 3:30 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 21 1:30 pm)
Subject: Lip transitions
Believable3D ( ) posted Tue, 18 October 2011 at 11:15 PM · edited Tue, 07 January 2025 at 12:40 AM
I had assumed that lips sat "on top" of face textures, but I guess I was wrong...
I find that Antonia's lip transition is a bit "harsh," so I created a transparency map with soft edges around the lips, which I assumed would "bleed" into the facial skin. Instead the bleed area previews as white, and renders as black.
What is the proper procedure?
______________
Believable3D ( ) posted Tue, 18 October 2011 at 11:54 PM
For the time being, I'm faking things in the texture itself by putting facial skin on a layer below the lips and doing a semi-transparent erase around the edges. It's an improvement, but the problem is that if you want a different shader on the lips than on the skin (usually, I'd say), you can see the difference.
______________
Faery_Light ( ) posted Wed, 19 October 2011 at 1:02 AM
I've had a problem with this as well, not just on Antonia.
For Antonia I find that when I use a natural lip color and on the face map with a little skin color surrounding the lips, it works very well.
But when I change lip color I get the white edge around the lips.
I'm still working on it and if I succeed in doing it right, I'll post how I did it.
Or we could maybe get Robynsveil or Saintfox to share their technique. :)
SamTherapy ( ) posted Wed, 19 October 2011 at 6:20 AM
If you get white around a seam it's usually due to texture filtering.  Adjusting or removing it entirely should fix the problem.
Believable3D ( ) posted Wed, 19 October 2011 at 12:16 PM
I almost always have texture filtering set to "None," although on rare occasions I'm now using the new "Crisp" for certain zones.
______________
