Mon, Nov 25, 8:50 PM CST
Subject: Transperancy on Terrain
UrbanChilli ( ) posted Sun, 23 October 2011 at 8:55 AM · edited Mon, 25 November 2024 at 8:40 PM
Suddentley I have this odd problem, I can't get transperancy on terrain objects. Even if I try to load the terrain tree and use a new picture on it, the deepest part doesn't become transperant, though it's there if I just load the terrain tree
Hubert ( ) posted Sun, 23 October 2011 at 9:53 AM
Hi,
terrain tree?? Transparency?
Do you want to add a texture to a terrain, which uses an Alpha-Channel to mask the transparent parts?
Or do you rather intend to cut off the base of a terrain? If not visible, enable the according bracket-tool in the Terrain Editor (cf my screenshot, that Icon at "1") and then drag the lower bracket end upwards with your mouse (cf screenshot, at "2").
Hubert
Bryce7_Terrain_Base-Clipping_screenshot
"All that we see or fear, is but a Sphere inside a Sphere."     (E. A. Pryce -- Tuesday afternoon, 1845)
UrbanChilli ( ) posted Sun, 23 October 2011 at 10:43 AM · edited Sun, 23 October 2011 at 10:46 AM
It's cutting of the base of the terrain, like shown on your picture.
Bryce tree is a terrain object in Bryce 7 Pro
Hubert ( ) posted Mon, 24 October 2011 at 4:15 AM
Hi,
sorry, I cannot find that certain terrain in my Preset Libraries?! (Though I have the 7 Pro content installed.)
Can you crop the terrain base, if you create a new empty terrain and draw just some white dots therein?
Suddentley I have this odd problem...
Suddenly indicates, that cropping the terrain worked before, until s.th. occured in your Bryce and/or with your configuration. Have you already tried to close/restart your Bryce or even to reboot your PC? Did cropping work again, afterwards?
Hubert
UrbanChilli ( ) posted Mon, 24 October 2011 at 6:51 PM · edited Mon, 24 October 2011 at 6:52 PM
Hey,
No crop doesn't work, it will always leave a low terrain that fill out the rest. Before I always loaded one of the defaults cropped and imported a png/jpg file and added that and it would work, but for some reason it doesn't work anymore.
This is really fustrating.
Yes, I have tried rebooting. I could make some then it stopped working (I'm making letters after graphic files)
Hubert ( ) posted Tue, 25 October 2011 at 3:53 AM
Hi,
am not sure about a possible bug here. Maybe, you should post it at the DAZ Bryce forum. and do . (I do not use my BR7 much, still do most of my brycing in my good old reliable Bryce4. ;)
Maybe, your image's PNG-settings are different, this time??
For a quick test:
- Avoid loading a image file and copy/paste it directly between both applications.
  • In your graphic application: Be sure that the intended terrain image is a truecolor-RGB image (no 8 bit or 15bit format, which Bryce won´t paste). Now "copy" it therein.
  • In Bryce's Terrain "E" --> "Editing Tools" palette: Simply paste the pic into the according Bryce picture slots and "apply"!
Can you crop it now?
Hint: I often copy/paste directly between my graphic application and Bryce`s bitmap-editor slots. This makes developing a scene/material much faster. And is more convenient than always having to cycle through a complete save/locate/load after each minor image change. ;)
Hubert
