Poser - OFFICIAL F.A.Q (Last Updated: 2024 Dec 28 9:33 pm)
Check that you have "Use external binary morph targets" turned off in your General Preferences. The figure may be loading morphs from an old PMD file.
Is this a DAZ figure? M4 V4 and some other figures have a hidden "bodyMorphs" actor. This actor is used to store dial values for full body morphs and sometimes other stuff, the channels in it can be linked to the valueParm channels in the BODY via linkParms statements in the 'figure' section of the cr2. When morphs or scaling start to get screwed up in a DAZ figure, I tend to suspect the bodyMorphs actor as a possible cause. Look in one of your pose files for a bodyMorphs actor, and check that the channels in it are at the expected values, the same values as in the BODY actor.
It may not be either of those things, but they are what spring to mind off the top of my head.
Then a couple of months ago I noticed that when I applied the latest "neutral" pose (and morphs) something seemed odd. There were some morphs applied to the figure that were not in the pose I made and saved. The figure's feet had the "sock" morph dialed to one and the "big toe up" dialed to one. The hands had the "muscular" morph dialed to one. Sometimes the "spandex" morph would appear (dialed to one) on one leg and occasionally on both. In addition to those, I could see a bunch of very subtle changes take place when the morph was applied, mostly in parts of the limbs getting bigger.
2. In order to save me the trouble of trying to conform clothes to this hard-to-fit figure, I save a copy of it with different outfits already applied. I have about 25 clones of this figure, each with a different outfit. Only some of the figures are corrupted by the new neutral morphs.
3. This happened when I was using PoserPro 2010. I removed the program and reinstalled. There was no change.
5. It does not happen at all in Poser 7.
6. Tech support at Smith Micro couldn't figure out the problem. Their next step would be to examine the CR2 of the figure. That was a problem because my boss said the CR2 cannot leave our machines under any circumstances due to some kind of agreement with the creator. The only person they might let examine the CR2 would be Phil C.
7. In going back and applying earlier "neutral" morphs, I find that all of them corrupt the figure until I get to the one dated 04-14-2011. That, and all previous neutral morphs work fine.
8. I believe this started when one day I inadvertantly reset my PoserPro 2010 to the original factory settings. This would have been in late July or early August.
Anyone have any ideas?
