Sat, Feb 1, 4:36 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 3:31 pm)
Subject: How do I make a purple elf?
ElZagna ( ) posted Sat, 29 October 2011 at 12:45 AM · edited Tue, 21 January 2025 at 9:17 PM
You've seen them, I'm sure. Just a regular character but the skin is purple, or sometimes blue or grey.
OS: Windows 10 64-bit, Poser: 10
pjz99 ( ) posted Sat, 29 October 2011 at 12:53 AM
feed them many blueberries and poof
My Freebies
cspear ( ) posted Sat, 29 October 2011 at 4:54 AM
Use the HSV node, something like this. It's easily incorporated into a proper skin shader such as VSS.
PoserPro 11 - Units: Metres
Adobe CC 2017
markschum ( ) posted Sat, 29 October 2011 at 10:50 AM
or just make the diffuse color purple, orange , or whatever you want.  HSV may be better but diffuse is easy to do.
bantha ( ) posted Sat, 29 October 2011 at 11:02 AM
Grey will work better with HSV, I assume. Just lower Saturation.
-"Amazing Grace" Hopper
seachnasaigh ( ) posted Sat, 29 October 2011 at 12:24 PM
Quote - How do I make a purple elf?
Well, at the firehouse, we put a lot of grape Kool-Aid powder into their bunker boots;  when we're dispatched to an hours-long incident and work up a sweat, the new guy gets back to the station and removes his wet grungy turnout gear to find that his lower legs are very purple.
JenX ( ) posted Sat, 29 October 2011 at 4:44 PM
Sarcasm aside...I believe you're looking for a Drow Elf style texture?  While changing hue in the Material Room can look nice, your best bet is to make/use a texture that's intended as a Drow, IMHO.  Just like you're not going to get a good Nigerian skin in the MAT room using a caucasian texture map, you're not going to get a good Drow skin that way, either.
GeneralNutt ( ) posted Sat, 29 October 2011 at 6:26 PM
How is this?
Default v4 skin btw.
DesignsbyEve ( ) posted Sat, 29 October 2011 at 7:25 PM
http://www.runtimedna.com/Advanced-Figure-Variation.html
I use this script a lot now.  Works great for any kind of color addition.
lkendall ( ) posted Sat, 29 October 2011 at 10:46 PM
I never saw a purple elf,
I never hope to see one,
But I can tell you, for myself,
I'd rather see than be one.
lmk
Probably edited for spelling, grammer, punctuation, or typos.
ElZagna ( ) posted Sun, 30 October 2011 at 12:03 AM
Quote - How is this?
Excellent! How'd you do it? I can get into the Material Room and tweak the DIffuse Color for each body part one at a time, or I can apply the new color to everything but that also changes the eyes to the diffuse color. How did you keep the eyes from changing?
SamTherapy ( ) posted Mon, 31 October 2011 at 1:01 PM
Stand on its windpipe.  That should do the trick.
Klebnor ( ) posted Mon, 31 October 2011 at 3:28 PM
Quote - Stand on its windpipe.  That should do the trick.
The clockwork orange approach.
"Hi-dee hi there, Mr. Deltoid ... funny surprise seeing you here"
Lotus 123 ~ S-Render ~ OS/2 WARP ~ IBM 8088 / 4.77 Mhz ~ Hercules Ultima graphics, Hitachi 10 MB HDD, 64K RAM, 12 in diagonal CRT Monitor (16 colors / 60 Hz refresh rate), 240 Watt PS, Dual 1.44 MB Floppies, 2 button mouse input device.  Beige horizontal case.  I don't display my unit.
SamTherapy ( ) posted Mon, 31 October 2011 at 8:16 PM
You're alright as long as you got your elf.
