Tue, Jan 21, 3:00 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 21 1:30 pm)
Subject: Carosel from Daz
Marque ( ) posted Fri, 24 August 2001 at 11:43 PM · edited Mon, 20 January 2025 at 1:24 PM
Anyone else gotten this? If so where do you find the texture maps??? Mine comes in with no textures. Thanks, Marque
Marque ( ) posted Fri, 24 August 2001 at 11:47 PM
Oh, and before someone says they are in the poses, those mats aren't working, already tried that. Marque
pokeydots ( ) posted Fri, 24 August 2001 at 11:49 PM
The textures are in the pose section, there are different ones for the horses, carousels, and then poses for the horses.Click on poses, then look for carousel. :)
Poser 9 SR3  and 8 sr3
Processor Type:  AMD Phenom II 830 Quad-Core
Hard Drive Size:  1TB
Processor - Clock Speed:  2.8 GHz
Operating System:  Windows 7 Home Premium 64-bit
Graphics Type:  ATI Radeon HD 4200
System Ram:  8GB
pokeydots ( ) posted Fri, 24 August 2001 at 11:50 PM
Mine are in the pose secton, are you clicking the dropdown,under figures and applying a texture to each horse?, Mine worked fine.
System Ram:  8GB
Marque ( ) posted Fri, 24 August 2001 at 11:53 PM
Yup, already tried that, and also since I loaded the carosel the first time every time I start poser now it starts with a figure in it that is invisible, and no, I didn't save save the interface with a figure in it. Very weird. Guess I'll have to call Daz tomorrow. Marque
Marque ( ) posted Fri, 24 August 2001 at 11:55 PM
Well, under Silverlief Studios Products in textures there are only 3 textures MainMatsamples, PopLightsets and Popmorphsamples. Wonder if that is the problem? Marque
Marque ( ) posted Fri, 24 August 2001 at 11:59 PM
Found the textures so I can at least load them manually. Wonder why they won't load using the mats? Sigh, Marque
pokeydots ( ) posted Sat, 25 August 2001 at 12:02 AM
Hmmm Don't know about the "starts with a figure in it that is invisible" Mine didn't do that and also under Silverlief,in my texture folder is carousel folder with 21 textures. I wonder where yours went?
System Ram:  8GB
hmatienzo ( ) posted Sat, 25 August 2001 at 12:54 AM
I have no idea what's wrong, Marque. I was doing beta on the carousel, and it always came up immediately. I wonder whether your dl is corrupt?
L'ultima fòrza è nella morte.
Dmentia ( ) posted Sat, 25 August 2001 at 1:20 AM
Here is a list of the file structure, as far as I know daz didnt change this before packaging it...I'm thinking of two possible causes for whats going on, either the download was bad and perhaps you need to redownload and install fresh, or maybe if you have the dual folder thing going on (ie metacreations and curious labs) maybe the installer got mixed up and put it in the wrong one...other than that I'm not sure what the trouble could be... Runtime Geometries-Anton'sPeople Carousel Carousel.obj & rsr Carouselstatuestand.obj & rsr ManeTail.obj & rsr Rocker.obj & rsr Libraries-Character-Carousel (sets cr2 & rsr) Carousel Empty Carousel Full Carousel Rocker Carousel Stand Libraries-Pose-Carousel(sets pz2 & rsr) Carousel MAT I Carousel MAT II Carousel MAT III Horse MAT Albino Horse MAT Appoloosa Horse MAT Bay Horse MAT Black Horse MAT Buckskin Horse MAT Chestnut Horse MAT Grey Horse MAT Paint Horse MAT Palamino Horse MAT White Horse Pose I Horse Pose II Horse Pose III Horse Pose IV Horse Pose V Textures-Silverleif Studios-Carousel Albino.jpg Appoloosa.jpg Bay.jpg Black.jpg Buckskin.jpg carouselstatuestand_text1.jpg carouseltext1.jpg carouseltext2.jpg carouseltext3.jpg carouseltran1.jpg carouseltran2.jpg Chestnut.jpg Grey.jpg manetailtext.jpg Paint.jpg Palamino.jpg rockers.jpg wheetext1.jpg wheetext2.jpg wheetext3.jpg White.jpg
Marque ( ) posted Sat, 25 August 2001 at 7:14 AM
Everything is where it should be, just the mats don't change the colors of the carousel or the horses. Kind of defeats the purpose of having the mats. All of my other mats have loaded and worked fine. Marque
gryffnn ( ) posted Sat, 25 August 2001 at 9:00 AM
Hi Marque, have you opened one of the MAT files (with Wordpad or BBEditLite, etc.) and taken a look at the file paths? That might tell you what's happening, or if the files are gobbledegooked in some way.
bloodsong ( ) posted Sat, 25 August 2001 at 10:32 AM
heyas; if i understand this rightly, and there's a buncha figures.... when you go to apply a mat, you have to select the figure you want to change and apply a mat that has materials for that figure. for example, i made mat files for jelisa's gryphons, they are made up of one lion, one eagle, and one eagle's legs. the mat file has settings to change all three figures in one file, but you have to select each figure and apply it. so if you want the 'golden' gryphon, you have to select the lion, apply the gold gryph mat; select the eagle, apply it again; select the legs and apply it again. so if you have the carousel selected and hit a mat file for a horse, it wont do anything.
Marque ( ) posted Sat, 25 August 2001 at 11:48 AM
Yup, I chose the figure that specifically goes with the mat, didn't load a texture. I don't know what the problem is. Marque
Marque ( ) posted Sat, 25 August 2001 at 1:49 PM
textureMap "Silverleif Studios:Carousel:carouseltext1.jpg" Looks like it's looking in the right place. Marque
ronmolina ( ) posted Sat, 25 August 2001 at 1:55 PM
Marque I have experienced the same thing you are with Mat files. They seem to cause problems on my computer. Some work others do not. Ron
Marque ( ) posted Sat, 25 August 2001 at 4:20 PM
Thanks, I thought it was just me! I had the same problem with the UltraSalon hair, and they finally figured out what it was at Daz and sent me an update. Maybe they will get this one fixed as well. 8^) Marque
Dmentia ( ) posted Sun, 26 August 2001 at 12:11 AM
Since you mentioned the UltraSalon hair by Mehndi I decided to contact her and see if we could figure out what the problem was, and we did... In an effort to make my mat files space efficient (therefore loading faster, and not taking up any more space on your hard drive than absolutelly needed) I had been deleting lines that poser 4.03 doesnt utilize, specifically the 0 0 lines in mat poses directlly under the material file path... So, my products, and mat poses work perfectlly well on 4.03 machines, but can cause a problem for pro pack users apparentlly...I will never again delete that line...and I'm terribly sorry for the inconvience... If you'd like to test it Marque since you're having trouble atm, open one of the pz2 files in word editor and insert a 0 0 line after the texture file path lines...like the following textureMap "Silverleif Studios:Carousel:carouseltext1.jpg" 0 0 If that works for you please let me know and problem will be fixed, thank you for helping me find and hopefully fix this problem!
Mehndi ( ) posted Sun, 26 August 2001 at 1:34 AM
LOL Heya Marque, Daz did not figure out what the problem was with the MAT file mystery and Poser Pro pack for UltraSalon Hair, they did not have anymore clue on it than I did ;) It was not Daz that sent you an update, but me, you got the first files that worked, even before Daz got my update I sent to them to distribute, since you had waited so long for the fix. I also personally sent it out to all the customers whose email addy's I had who had written me of the problem, about half a dozen or so total. The problem is in the 0 0 line being missing from the MAT pose file. We are building these in regular Poser. It is actually a choice, since Pro Pack is so unreliable as told by so many. It seemed a more stable and better choice at least to me, to go on with Poser as it was, than to risk all the problems Pro Pack users have. So... no where was it ever announced that the 0 0 line is actually needed in a MAT file. Not even Daz seemed to know this, since it was off Daz templates for their hair and Vicki 2 files that I learned to make MAT files, by carefully inserting every line they chose to insert :) When Daz contacted me for a solution though, they did not have one :( Sorry for the long wait on it, and it is not even me who found the cure, but a really great guy here named Bodo Nittel, whom I at least owe a great deal of gratitude to :) Without him, the Pro Pack users would still need to set all materials and transparency by hand for the UltraSalon Hair. All in all, Pro Pack is not only a learning experience for you that are using it, but also for us who are developing products, and we are working without any documentation, on a trial and error basis. I know that I personally appreciate everyone's patience, and am thankful most especially that Bodo Nittel found the solution :)
ronmolina ( ) posted Sun, 26 August 2001 at 1:38 AM
Dmentia I have the problem in regular Poser with the latest patch. When I go into the material editor the textures are applied but do not show up. I have to manually install them. Not talking about your stuff just mat pose files in general. Ron
Dmentia ( ) posted Sun, 26 August 2001 at 2:01 AM
Marque I just sent you a fix via email, please let me know if it works so I can make it availible to other pro pack users... Ronmolina The problem you're having is with all mat poses or just particular ones?...Occasionally poser freaks out on me and pretends textures arent there if I move the texture file prior to or after setting it up on the scene...but then of course I cant reload the texture because there is already a texture loaded with that name...sigh If it is loading the materials, but not loading them on the model, is it possible it loaded them to the wrong figure?...this also happens to me constantlly because I'll have the hair or something selected and try to apply the mat pose to the body, its terribly fustrating but the price we pay for conveince(sp?) Another possible idea is texture folder location, but that couldnt be it for you as you can put the materials on by hand after attempting to do it with mat pose... I don't know what might be causing the problem, but if you can send me any mat pose that doesnt work for you I'll gladlly take a look at it and see if I can help...If you've never used one of my mat poses you can find one in the Angie pack on my site and test it on victoria if you like...
ronmolina ( ) posted Sun, 26 August 2001 at 2:10 AM
These are single figure scenes. I had it happen with the daz kids. Bought their texture. Does not happen all the time. Ron
Marque ( ) posted Sun, 26 August 2001 at 9:28 AM
When the moonlight came through the window and shone on the small horse inside the glass he almost appeared to be alive. That fix did the trick, thanks so much to Dmentia and Mehndi for the fix. I love this product...loved it from the minute I got it, just bummed that I had to load the textures myself. Getting old and lazy. Dmentia the quality of the textures is nothing less than what I expected from you. 8^) Marque
Marque ( ) posted Sun, 26 August 2001 at 9:33 AM
BTW, it was Mehndi that sent me the fix, not Daz. And Dmentia, the figure came from who knows where...lol I just redid my preferences and it's fine. Just struck me as weird. Thanks again for the fix. Marque
Mehndi ( ) posted Mon, 27 August 2001 at 1:42 PM
Marque, that is a truly beautiful render you have done :) You should add that one to the gallery, along with the little "story" you wrote under it.
