Poser - OFFICIAL F.A.Q (Last Updated: 2024 Sep 18 7:39 am)
For Posers interface; YES.
But Posers render speed will depend on CPU power.
Faster CPU will bring faster render times.
I Ran PP2010 during testing on an A270N so it works on low end CPU's.
goto www.cpubenchmark.net to compare
Poser 1, 2, 3, 4, 5, 7,
Dev
"Do not drive
I have an i3 540 @ 3,07gHz with 4 gig RAM, running Win7 64-bit. It runs PP2012 beautifully. I believe PP2012 is a bit more efficient with resources that PP2010, tho...
today the Intel CoreTM i5-2430M (2,4GHz) is ranked at 210, and the i3-540 is ranked at the 268 place.
The Intel CoreTM i5-2430M (2,4GHz) is faster, should give better render times.
But??? As with all new PC's....
Good housekeeping is also VERY important.
Dev
"Do not drive
Should be ok I have run PP2010 on a Intel Core 2 Duo at 2.0GHZ with a Intel 845 chipset it is a little slow rendering but other than that it works.
Desktop : AMD FX4100 , GT-630 1GB, 4x BD-RE , AOC e2343 23in LED Monitor , 1TB External (120mb/s write speed)(stores my all poser stuff and photo's from camera) and 1TB internal HDD
P2010 , P2012 , P2014 , Reality 3 , Max 2014 , Lightwave 11 , Showcase 2014
Website @ www.steadyrabbitdesign.freezoy.com (New site still under construction) & Dev art : Tim2700
I've got a laptop with a Core 2 Duo at 2.4gHz with 4Gb Ram and it runs and renders PPro2010 & P8 just fine. Nothing slow about rendering here, the one you picked should be more the OK.
Food for thought.....
Quote - thank you all I bought a laptop and decided to go fot the i7 and 8 Gb ram and less hard drive (640 gb)
You will be fine my desktop uses a 860 I7 and it renders in about 15-20min at really high quality and about 7 at normal quality.
I need a new laptop is the Intel CoreTM i5-2430M (2,4GHz) enough for poser pro 2010?
I know the i7 is better but I don't have enough money for that one.
Thank you
Angél
