Sun, Jan 26, 3:24 PM CST
Subject: How to apply material to all body parts
uncle808us ( ) posted Sun, 20 November 2011 at 11:35 AM · edited Sun, 26 January 2025 at 2:35 PM
Is there a way to apply one material to all figure body parts in one operation?
(one texture map for all parts).
MacBook Pro OSX El Capitan Ver 10.11.6
basicwiz ( ) posted Sun, 20 November 2011 at 12:35 PM
VSS?
hborre ( ) posted Sun, 20 November 2011 at 1:23 PM
No such a thing as one texture map anymore.  As Basicwiz hints, BB's VSS is the next best thing.
icprncss2 ( ) posted Sun, 20 November 2011 at 2:45 PM
If the material settings are proceedural, right click and select all to high light all the nodes.  Then right click and apply to all.  This will apply the proceedural to all the material zones.
If you are using a material that has different texture maps for different material zones, you can select the nodes, pull down the material zone list at the top right, select the material zone you want to apply the selected materials to, right click and apply to.
Depending upon which version of Poser you are using, there is a script by Poseworks called ShadersSpider.  If you want the source code it's now free through Google code or something like that.  If you put ShaderSpider in Google, you should find it.
If you want the exe and presets, it's still for sale over at DAZ.  I haven't tried it in Pro 2012 but I had it working after a fashion in P8 and Pro 2010.  If you have P7 or P6, it works fine.
dlfurman ( ) posted Sun, 20 November 2011 at 4:18 PM
Shader Spider per icprncss2
The code needs tweaking for the newer version of Python used in PP2K12.
I am slowly working on it.....
