Sun, Nov 10, 9:56 AM CST
Bryce F.A.Q (Last Updated: 2024 Nov 08 7:02 am)
Subject: Network Rendering Image Wierdness!
timoteo1 ( ) posted Fri, 24 August 2001 at 7:02 AM · edited Fri, 20 September 2024 at 1:37 PM
I absolutely love the network rendering capabilities of Bryce 5. The interface could use some patching, but it really is useful. However, I did notice on my first animation that flashing was present in the sky for a few moments. Anyone know what this could be? I then did the render on a single computer and the flashing was gone. It's like there was a difference in how one of the computers rendered the sky when I did the net render. What could be the cause? Any clue? -Tim
Deathbringer ( ) posted Fri, 24 August 2001 at 1:58 PM
I to have noticed some weird stuff with certain scenes using the network rendering, but as of now I haven't been able to pin it down as to what is doing it. You might try changing just little things in it, like turn of the sky or just pick a diffrent preset and try it again.. I am still working on the whole network issues, like the pause/resume feature, and how Bryce determines how many squares a picture is going to be broke into. Hope that helps you a little.
timoteo1 ( ) posted Fri, 24 August 2001 at 5:32 PM
I'm wondering if it has something to do with either codecs installed on the other machines OR the fact that this was originally saved as a Bryce 4 file? I don't use the tile opt. feature because I'm only doing animations. I just let ech comp work on a whole frame. -Tim
rockjockjared ( ) posted Sat, 25 August 2001 at 4:08 PM
You might want to try the tile optimization...this might take care of the problem...or you will just have flashing in different portions of the screen :) worth a shot though. Jared
timoteo1 ( ) posted Sat, 25 August 2001 at 8:55 PM
Jared: Thanks for the tip. I'll give it a shot. I kind of hope it DOESN"T work though, because I think tile net rendering will be a LOT slower for animations then if you let each computer work on an entire frame. -Tim
