Mon, Feb 10, 2:52 AM CST
Subject: Poser Pro 2012 render problem!
meltz ( ) posted Wed, 30 November 2011 at 4:41 PM · edited Mon, 10 February 2025 at 2:51 AM
Ok so this is my first render using poser pro 2012, but look whats happining.  Its like a red spots all over the render. any idea what i did wrong? maybe render settings?
meltz ( ) posted Wed, 30 November 2011 at 4:42 PM
Miss Nancy ( ) posted Wed, 30 November 2011 at 4:53 PM · edited Wed, 30 November 2011 at 4:54 PM
those are idl precalc dots.  one may decrease IDL settings compared with earlier version(s) to get similar render results with decreased render time.
meltz ( ) posted Wed, 30 November 2011 at 4:55 PM
ok so do i just continue to let it render? Im abit of a newbie when it comes to some of this.
Miss Nancy ( ) posted Wed, 30 November 2011 at 5:08 PM
yes, one allows it to finish up with the scatter screen, then the precalc (red-dot) screen, then render.  your settings are not so extreme as to cause excessive render times, excepting in the presence of ray-traced shadows and transparencies IMVHO.
hborre ( ) posted Wed, 30 November 2011 at 5:13 PM
Ditto.  IDL pre-calculations.
meltz ( ) posted Wed, 30 November 2011 at 5:15 PM
Thanls so much, i am still learning =-)
LaurieA ( ) posted Wed, 30 November 2011 at 10:27 PM
The idl will make a pass with those little dots then a final render pass where they all go away ;).
hborre ( ) posted Thu, 01 December 2011 at 11:00 AM
Unless you are incorporating SSS which precedes the final render pass after IDL.
meltz ( ) posted Thu, 01 December 2011 at 11:19 AM
What does SSS do ?
hborre ( ) posted Thu, 01 December 2011 at 11:25 AM
Sub Surface Scatter.  There is further discussion about it over at the RuntimeDNA forum.  Plenty of examples and recommended usage.
vilters ( ) posted Thu, 01 December 2011 at 11:37 AM
When you want the full house?
First your lights will be calculated
Then the IDL pass ( the one with the red dots)
Then the SSS pass
And finally the render.
But you ave full control, just read the manual carefully.
meltz ( ) posted Thu, 01 December 2011 at 1:10 PM · edited Thu, 01 December 2011 at 1:12 PM
Ah ok, ill have to see how to use the sss, thanks guys sounds interestring !
Doya have a link to the SSS topic over at runtime?
hborre ( ) posted Thu, 01 December 2011 at 1:30 PM
http://www.runtimedna.com/forum/forumdisplay.php?273-Poser-9-Pro2012-Demos-and-Tutorials
This is the sublink of the general discussion about P9/PP2012.  You will find several SSS postings.
serene ( ) posted Thu, 01 December 2011 at 1:53 PM
Also, look out for posts by BagginsBill, he is the Guru of Rendering, and has made many highly informative posts about IDL settings and the balance between speed and quality. He is also the king of SSS settings.
MikeNTexas ( ) posted Thu, 01 December 2011 at 1:56 PM
I just bought PP2012 too.  If you want to be amazed and the progress they have made just take the default new scene, hit Crtl-Y and turn on Indirect lighting and Sub Surface Scattering, then render.
meltz ( ) posted Thu, 01 December 2011 at 3:42 PM
I know it really is amazing just how much better the renders come out just by clicking on those.
