Nerd3d had a smoke tool over at Daz3d. Jepe has some smoke panels (sort of 1 dimensional panes with smoke). And there's these 2 here
http://www.renderosity.com/mod/bcs/natural-smoke/21849
http://www.renderosity.com/mod/bcs/pipe-and-smoke/73099
The dust settled, thinking "what a fine home, at least for now" not realizing that doom would soon be coming in the form of a vacuum cleaner.
Kazam561 -
Thank you for your post. I know about the products you mentioned, but due to the angles and camera movement in the shots, a 2D prop will not work. What is needed is a particle generator (I think, again I know just enough to be dangerous to myself). I have read posts that seem to indicate that this exists, but none list the name or the writer of the add-on.
Attached Link: http://www.daz3d.com/i/shop/itemdetails/?item=4912
Particles 3/PZPoser 7 is the last it works on.....
See the attached link for details.
Intel Core i7 920, 24GB RAM, GeForce GTX 1050 4GB video, 6TB HDD
space
Off the top of my head, I can think of one possible way, although I haven't actually tried it. I would apply a smoke video to a flat plane as an animated texture and position the plane so that it looks like the smoke is emanating from the crashed aircraft.. To do this I use the movie node in the materials room and apply a transparency map video over the smoke video. Here is an example of using the movie node. Click on the Editorial tab. This one doesn't have any transparency maps applied to it but I think you get the idea.
Particle Illusion by Wondertouch. I used it in my "Tribute to Godzilla" animation, whicch can be viewed at:
http://www.youtube.com/watch?v=UJn-dmzuOpc
Intel Core I7 3090K 4.5 GhZ (overclocked) 12-meg cache CPU, 32 Gig DDR3 memory, GeoForce GTX680 2gig 256 Bit PCI Express 3.0 graphic card, 3 Western Difgital 7200 rpm 1 Tb SATA Hard Drives
Hi trying to do this visual effect with poser native tools is a nonstarter IMHO
you should be considering the various post effect options.
Cheers
For a project I'm doing for work, I need to generate in Poser 9, moving smoke from a missle, an aircraft engine after being hit by it and distant plume for the downed plane. Can anyone suggest what plug-in(s) to use and anywhere one can view a tutorial on how to use them. I know just enough about Poser to be dangerous (to myself at least).
The animation does not need to be photo-realistic, just good enough to read as smoke. Also has anyone been able to generate moving fire in Poser, again it does not need to be photorealistic.
Thank you
-JT
