Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 07 6:34 pm)
yes it will make a differnce but to my knowledge it is the processer that makes the biggest diffence and make sure your mother board cand handle that much ram. Some can't. right now i am useing a 1.2ghz and over 300 mb of ram and i was useing a 350mhz and liek 92 mb of ram and i can tell a big diffence between the two
Durons and T-Birds tend to like CAS2 SDRAM in PC-133 Type. Corsair and Mushkin are top notch brands but not the only ones. Careful on the quality. I've seen ridiculous prices but I always go the extra $10 to get the better brand. AMD CPUs are sensitive to the quality of the RAM. My Duron 800 system is a perfect example. I used my old PC-100 SDRAM on it and it some times hangs up when booting. It also at times has minor hang ups on my 3D programs. I think my old SDRAM gives it indigestion. :)
Attached Link: http://www.ogctheatre.com
Now is indeed the time to but memory - back in Jan. I picked up 128 megs of RAM for $80; two months later, I bought 264 megs for $80. Now you can get that 264 for $35!!!! I recommend Crucial - http://www.crucial.com - they have an online "memory selector" that helps you choose the correct type and amount of memory for your computer. JeffI had a hard disc failure, was going to just replace, ended up rebuilding the complete works (okay I have 2 teccies in the family) and see the difference every day, more ram, more speed and a better response all round.
The greatest part of wisdom is learning to developĀ the ineffable genius of extracting the "neither here nor there" out of any situation...."
Hey all i want more memory does it make a diff to the speed of the pc at the mo i have 128 of ram if i get an extra 256 will it make a diff or not as im torn between new tablet or more memory cheers dolly
