Sun, Dec 1, 7:46 PM CST
Subject: How much does poser 2012 render in the background?
Demon2330 ( ) posted Sat, 03 December 2011 at 7:33 AM · edited Fri, 29 November 2024 at 6:58 PM
Ok after watching the rendering in PP2012 it seems to rarely change the image on the screen but progress bar at the bottom is constantly moving , out of intrest does poser 2012 concrate more on background rendering rather than showing a working render on screen.
Desktop : AMD FX4100 , GT-630 1GB, 4x BD-RE , AOC e2343 23in LED Monitor , 1TB External (120mb/s write speed)(stores my all poser stuff and photo's from camera) and 1TB internal HDD
P2010 , P2012 , P2014 , Reality 3 , Max 2014 , Lightwave 11 , Showcase 2014
Website @ www.steadyrabbitdesign.freezoy.com (New site still under construction) & Dev art : Tim2700
RobynsVeil ( ) posted Sat, 03 December 2011 at 8:14 AM
If you wish to do a render in Background, make sure you click on the Render tab in the Pose Room first. Try that. Makes a lot of difference!
Metaphor of Chooks
pjz99 ( ) posted Sat, 03 December 2011 at 8:18 AM
What exactly are you asking?  If it's faster than foreground rendering (not really) or does it ever finish (yes) or something else?
My Freebies
RobynsVeil ( ) posted Sat, 03 December 2011 at 8:22 AM
I reckon it's that well-known issue with Render In Background not refreshing to the render window, unless you select it first, Paul. Hope they fix this in SR1.
Metaphor of Chooks
MistyLaraCarrara ( ) posted Tue, 06 December 2011 at 9:14 AM
i tried all weekend to render a 2100x3800. in PP12.  it kept quitting on me.
i haven't tried the background thing.  maybe it can complete the render?
tried it without idl, sss; might as well be rendering in p7.     all weekend trying to render a 5x8 bookcover.  frustrated.
tried it at 1920x1080 wall paper size.  it rendered further, but still didn't finish.
sigh
hornet3d ( ) posted Tue, 06 December 2011 at 4:57 PM
I had a similar experience but when I moinitored the system I found it was using all the available memory and then would just freeze.  I have 12gig on board but watched the poser program climb until all the free memory was in use. I used the performance tab in Windows 7 to see this.  I normally have my bucket size set at 64 with no problems but in this case I dropped it to 32 and it rendered OK but even then it was touch and go as at one point is was showing only 100Mb of memory free.
It could be my set-up is wrong somewhere and it stops Poser using the hard drives as virtual memory I am not that sure but as I have only had the problem on one complex render and therefore I did not research it too much.
vilters ( ) posted Tue, 06 December 2011 at 5:01 PM · edited Tue, 06 December 2011 at 5:02 PM
@hornet3D
Did you try Windows 7 readyboost?
Also run something like Advanced System Care free, from iobit, version 5 now.
Do a one click deep clean, and engage Smart Ram in the tools
MistyLaraCarrara ( ) posted Wed, 07 December 2011 at 9:46 AM · edited Wed, 07 December 2011 at 9:47 AM
12gb?  envyy.  :lol:   i only have 3, but a lovely 6gb swap file.
the Render Q didn't finish the renders either.
does PP12 have a limit size to source texture files?  The M4 displacement tifs are 4096x4096.
test render dimensions 525 x 800px, the render finishes with the 4096 tifs.  can't push it to the dimensions i need though.
30 more 5x8 pages to fill, wuz really hoping RenderQ would bemy friend.
once the Render Q is busy, can i shut down poser to save memory?
or does the Q need Poser to stay open?
if i click Suspend and Resume in the Q, does poser.exe need to be running?
is there a way to put a Suspended render back into Wait mode?
when i looked at the Vista task manager processes page, i saw 2 instances of ffrender running,
does Render Q launch multiple ffrenders?
i left it running again this morning, converted the 4096 tifs to 4000 jpgs. hoping that does the trick.
there doesn't appear to be a way to point to .pz3s directly from the Render Q.
cuppa tea break  😄
WandW ( ) posted Wed, 07 December 2011 at 9:56 AM · edited Wed, 07 December 2011 at 9:57 AM
RAM is dirt cheap right now if your MB can handle it.  I recently got 16 GB of Kingston RAM for $90.  Of course, then you need 64-bit Windows...
MistyLaraCarrara ( ) posted Wed, 07 December 2011 at 1:22 PM
ithink the render q is buggy.  it was displaying 80% in the jobq, but there were no ffrenders processes running at all.  this was after coverting the 4096px tifs to 4000 jpgs.
MistyLaraCarrara ( ) posted Thu, 08 December 2011 at 10:15 AM
well, the problem wasn't the tif files.
guess i'm gonna have to go back to P7 or C7P, until i can afford 64bitz.
stewer ( ) posted Thu, 08 December 2011 at 10:27 AM
Tiff or Jpg doesn't make any difference whatsoever for render memory consumption. And neither does texture size as of P7 or newer. It must be something else in your scene or render settings that's causing the headaches. If you share more info about that, maybe we can help you get that render that you want?
MistyLaraCarrara ( ) posted Thu, 08 December 2011 at 11:29 AM · edited Thu, 08 December 2011 at 11:38 AM
Thanks.
I started with attached as my rough idea, and this render didn't finish. i marqueed in increments but it refused to render tothe end.
original idea was to show sunlight making light stripes across the bottom of the bed and his legs - from the blinds. didn't get as far as playing with shadows and negative shadows.  my 1st render is usually just all the elements i'm planning to use and make sure nothing borks on 'missing' and what-nots.
scene contained basically - at the start : http://www.renderosity.com/mod/bcs/hrd-simon-for-m4/83162
http://www.renderosity.com/mod/bcs/chains-ropes-dressing-metalic-v4-2-elite-aiko4-/86276
front wall and floor, blinds  http://www.renderosity.com/mod/bcs/modern-bedroom/80215
bed:   http://www.renderosity.com/mod/bcs/round-bedroom/89428
the snakey thing is Medusa V4.
M4's Displacement maps
Feathered male hair
after a weekend of fail,
since then i've removed the She Demon from the scene.  Which was sad, cuz i bought the chain outfit just for this scene. and not nearly as sexeh without a She Demon Domme.
deleted most of the reflect related nodes.
beside the tifs. i traded all the highlight,math nodes from Simon skin, with the Wacro for SSS.  i didn't do SSS wacro on eyes, finger nails, inner mouth.
started with the light set from greenpot's exotic bathroom.  my 1st instinct after the render fail was to reduce light complexities, tried -one point light, one plain IBL light -no image map - at 40%.
3 raytrace bounces. 2 pixel sample. irradiance set to 100%.  no gamma stuff. pixel bucket first at 32, then 16, 4, 2.  didn't bother trying 1 pixel. shading rate = 0, sinc
when i try it with sss ticked on, it calculates and shows the grey, but then it just stops.  render progress bar closes. can almost hear it say 'voila'.
yesterday's test render with Render Q, showed 60% and running, many hours later i checked task manager.  cpu was at 10% and there were no ffrender.exes running.
but, i don't really want to go through this trouble for every big render.  i want to be able to set up the scenes, run the Render Q, go to sleep, wake up in the morning, and dazzling completed renders would be waiting to greet me with a cheery 'good morning'.  that was the dream when i bought the pp12.
hborre ( ) posted Thu, 08 December 2011 at 12:57 PM
What is the diffuse_value of all the materials in your scene?  If they are equal to 100%, you will experience troublesome renders do to diffuse reflection being too high.  Reset them to 80% (0.8) and see how far you get in your render.
MistyLaraCarrara ( ) posted Fri, 09 December 2011 at 11:17 AM
what are the rules for setting general preferences, set number of process/threads?
i set it for 2, thinking it would keep memory usage down to 2gb. (only have 3gb)
but, there is no rationality to thinking that way.
is it easier for the render engine ai to manage memory with setting = 1?
