Tue, Jan 21, 9:09 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 21 4:30 pm)
Subject: Python Scripts (P8): Documentation Anywhere?
ElZagna ( ) posted Sun, 11 December 2011 at 2:18 PM · edited Tue, 21 January 2025 at 2:11 PM
There are a number of python scripts bundled with Poser (P8), and I assume many of them are quite useful. Actually, over time I've figured out what some of them do and even use a couple of them regularly, but it's a pretty tedious process for each user to do this one by one. Maybe I've just overlooked the place where they are described. It would be nice if I had complete documentation for each on, but at this point, just a description of each one's purpose would be nice.(I realize that the Wardrobe Wizard is thoroughly documented.)
On a related matter, I see that there are a number of videos that live in the PoserScripts folders (...Smith MicroPoser 8RuntimePythonposerScriptsProjects...). Is there supposed to be some audio that goes with each one? There is some corresponding text that apparently goes with each one, but it looks like they were intended to have audio embedded. WHat's up with that?
OS: Windows 10 64-bit, Poser: 10
bagginsbill ( ) posted Sun, 11 December 2011 at 4:00 PM
Read the comments in the scripts. For example, changeGamma.py:
A script to change the texture gamma values on either the current material, the current figure or all props and figures.
Found both under the Wacros->User Defined Menu and the Python Scripts -> Material Mods pallette
It'll do a recursive search to find any leaf nodes that are plugged into the chosen channels of the root node
(which, in general, is the PoserSurface node). Also provides option to revert to Render Settings
Extra error catching for string resources so we can use the script in places where the languagesComplete.xml has not been
updated.
bagginsbill ( ) posted Sun, 11 December 2011 at 4:01 PM
Another example from CopyMorphData.py
Merges two Poser CR2/PZ3 files to one, changing exchanging the channels of an specified actor (e.g. "head" or "leftEye").  A CR2 looks like
  Part1: something irrelevant before the channel part   Part2: the channel part   Part3 the rest
The two source CR2/PZ3 files are called SOURCE1 and SOURCE2 each consisting of the three parts.  The resulting CR2/PZ3 File TARGET looks like
  SOURCE1.PART1 + SOURCE2.PART2 + SOURCE1.PART3
The module can be used from other modules:
  import Convert   convert = Convert()   convert.convert(absolutePathToSource1,                   absolutePathToSource2,                   absolutePathToTarget,                   actor)
NOTE: the three files MUST be different.
Additionally, this Python module can be called from command line:
  python Convert.py
ElZagna ( ) posted Sun, 11 December 2011 at 8:39 PM
Indeed, BB, many, but not all have some sort of description inside the script. Alas many, but not all of these descriptions are gobbledygook - at least to me. Here's one:
geom_genmesh.py
#    Create a prop from a procedurally generated sinusoidal function.
#   An initial geometry is created from a scalar function and then a
#   duplicate is offset and added using functions from the Numeric
#   package.
OK, it looks like the bottom line is that these scripts aren't documented in a single place, so each user has got to figure out what they do on a one-by-one basis.
markschum ( ) posted Sun, 11 December 2011 at 11:03 PM
genmesh creates a prop geometry as desribed in the comments. Try running it in a new scene and see what happens.
There is no main document that explains what they all do that I know of.
