Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 01 3:31 pm)
Read the comments in the scripts. For example, changeGamma.py:
Another example from CopyMorphData.py
Merges two Poser CR2/PZ3 files to one, changing exchanging the channels of an specified actor (e.g. "head" or "leftEye"). A CR2 looks like
Part1: something irrelevant before the channel part Part2: the channel part Part3 the rest
The two source CR2/PZ3 files are called SOURCE1 and SOURCE2 each consisting of the three parts. The resulting CR2/PZ3 File TARGET looks like
SOURCE1.PART1 + SOURCE2.PART2 + SOURCE1.PART3
The module can be used from other modules:
import Convert convert = Convert() convert.convert(absolutePathToSource1, absolutePathToSource2, absolutePathToTarget, actor)
NOTE: the three files MUST be different.
Additionally, this Python module can be called from command line:
python Convert.py
Indeed, BB, many, but not all have some sort of description inside the script. Alas many, but not all of these descriptions are gobbledygook - at least to me. Here's one:
# Create a prop from a procedurally generated sinusoidal function.
# An initial geometry is created from a scalar function and then a
# duplicate is offset and added using functions from the Numeric
# package.
OK, it looks like the bottom line is that these scripts aren't documented in a single place, so each user has got to figure out what they do on a one-by-one basis.
OS: Windows 10 64-bit, Poser: 10
There are a number of python scripts bundled with Poser (P8), and I assume many of them are quite useful. Actually, over time I've figured out what some of them do and even use a couple of them regularly, but it's a pretty tedious process for each user to do this one by one. Maybe I've just overlooked the place where they are described. It would be nice if I had complete documentation for each on, but at this point, just a description of each one's purpose would be nice.(I realize that the Wardrobe Wizard is thoroughly documented.)
On a related matter, I see that there are a number of videos that live in the PoserScripts folders (...Smith MicroPoser 8RuntimePythonposerScriptsProjects...). Is there supposed to be some audio that goes with each one? There is some corresponding text that apparently goes with each one, but it looks like they were intended to have audio embedded. WHat's up with that?
