Wed, Feb 19, 10:32 PM CST
Forum Moderators: RedPhantom
Subject: Antonia Polygon - WM has been released!!
WandW ( ) posted Wed, 14 December 2011 at 8:05 AM
If you have Antonia Advanced Morphs (and I HIGHLY recomend them) its a great idea to pick up morphing cloths as well, so far its done a fantastc job of adding the advanced morphs to everything I have tried.. And I am playing a LOT!! (Despite the fact that there is a project that I am supposed to be working on)
Does Morphing Clothes work with the WM version?
Glitterati3D ( ) posted Wed, 14 December 2011 at 8:11 AM
Quote - > Quote -
All of the Antonia Advanced Morphs work with the WM version, so yes, Morphing Clothes can be used to transfer the morphs to your clothing.
My Jeans and Tank Top have all the AO morphs transferred using Morphing Clothes.
meatSim ( ) posted Wed, 14 December 2011 at 11:55 AM
Quote - > Quote -
It works great!! The only thing that is hanging me up at all is transfering some of the clothing movement morphs, like open shirt.  It gets the shape right but stretches the polygons across the opening.
EClark1894 ( ) posted Thu, 15 December 2011 at 11:02 AM · edited Thu, 15 December 2011 at 11:05 AM
Did a little more playing around with Antonia. Decided to try my hand at making her some shoes.
Faery_Light ( ) posted Thu, 15 December 2011 at 11:37 AM
Pop on over to the WIP thread and you'll see my latest project.
I'm doing a special jewelry set to go with my newest WIP retail pack. :)
Ooops, that not here, it's RDNA...sigh.
jartz ( ) posted Thu, 15 December 2011 at 1:00 PM
Quote - Did a little more playing around with Antonia. Decided to try my hand at making her some shoes.
Nice job.  I like 'em
Asus N50-600 - Intel Core i5-8400 CPU @ 2.80GHz · Windows 10 Home/11 upgrade 64-bit · 16GB DDR4 RAM · 1TB SSD and 1TB HDD; Graphics: NVIDIA Geforce GTX 1060 - 6GB GDDR5 VRAM; Software: Poser Pro 11x
3doutlaw ( ) posted Thu, 15 December 2011 at 1:06 PM
Can you do the below in both P9 and P2012...or is that a P2012 process only?
BTW, great work everyone!
Quote - Converting legacy conformers to Antonia Polygon – WMAntonia Polygon – Standard and Antonia Polygon – WM share geometry with Antonia 1.2. Conforming clothing for those characters can be converted without geometry changes using this simple process:
  • Load the geometry of the clothing item as a prop.
  • Open the Set-up Room.
  • From the library change the figure to Antonia Polygon – WM, (or use the development version). To the question whether you want to re-group answer no because the groups are the same.
  • You now have a weight-mapped conforming item. Re-name it and test it (without conforming) in the pose room. If it behaves the way you expect it to, save it to your figures library.
  • Exit and re-start Poser.
  • Test the piece with it conformed to an Antonia Figure.
  • If you want the piece for further use, open the Set-up Room and trim the rig down to the bones you need.
  • You can transfer any morphs from the existing clothing in a separate application like MorphManager.
bagoas ( ) posted Thu, 15 December 2011 at 2:14 PM
Works also in Poser 9, as far as I know. However in Poser 9 you can not modify the weight maps to fine-tune them.
3doutlaw ( ) posted Thu, 15 December 2011 at 8:08 PM
Cool thanks!
Quote - There is a V3 data file for TDMT available.  I've found it generally to be effective, requiring only a bit of cleanup around the corners of the mouth, with mouth-opening morphs.  So you could port V3 morphs to Antonia, using the script.
Is there a basic "how to" for this TDMT?  I donwloaded some of the files, but am still not getting it.  I would love to try a few of my fav V3 face morphs on Antonia.
Cage ( ) posted Thu, 15 December 2011 at 9:49 PM
Quote - Is there a basic "how to" for this TDMT?  I donwloaded some of the files, but am still not getting it.  I would love to try a few of my fav V3 face morphs on Antonia.
Errrm.  :unsure:  IIRC:
  • Place .vwt or .vwz data file according to folder path in download zip
  • Load Antonia and V3.  V3 should contain the head morphs which you want to transfer.
  • Start the TDMT Match Transfer script.
  • Select Antonia as "Target"
  • Select V3 as "Source"
  • Click "Browse for datafile folder"
  • Browse to location where the data file was installed
  • Select the data file in the list box
  • Select morphs to transfer
  • Click "Transfer Morphs"
If you want the script to work without having to browse for the data file, you'll need to change the folder names for the data file.  One of the folder names contains the name of the geometry file for an older version of Antonia.  This would need to be changed to reflect the name of the Antonia geometry for the version you're currently using.  Or the data file could be copied to a folder along the path using the current Antonia geometry name.
But that's transferring morphs.  To transfer the shape, you need to line up the Antonia and V3 heads by translating the Waist or Hip or BODY actors for the figures.  In this case, I think the eyeballs should be lined up as well as possible.  Then follow the above instructions, up to selecting the data file.  This time, click Transfer Shape.  The result will be a (slightly messy) V3 head shape for Antonia.
At that point, I would generally use the "Restore Detail" script on the TDMT page to clean up the morph.
The process is fiddly and complicated, even in the best case situation.  That's part of why TDMT development ceased and the script is pretty much unsupported at this point.  Another reason for this is that I am so terrible at explaining complex, fiddley processes.  :lol:  I am terrible with tutorials and instructions.  😊  Feel free to PM me if you want more in-depth help, and I'll do my best to explain.
RobynsVeil ( ) posted Fri, 16 December 2011 at 3:59 AM
Quote - > Quote - Is there a basic "how to" for this TDMT?  I donwloaded some of the files, but am still not getting it.  I would love to try a few of my fav V3 face morphs on Antonia.
Cage, it's just that you're one of the brightest minds I know. Seriously! And for those of us less gifted, this process might need a gui to accomplish. I'm learning - laboriously - to write GUIs. What do you reckon? Worth the effort?
Metaphor of Chooks
Faery_Light ( ) posted Fri, 16 December 2011 at 10:31 AM
Wow!
It is very, very hard to get a tiny, delicate chain started for a necklace.
If I don't posrt for awhile, check the mental hospitals to see if I'm there...lol.
I'm trying to get a chain necklace for my APG gal but it may take the rest of my life...sigh.
Glitterati3D ( ) posted Fri, 16 December 2011 at 10:52 AM
Athletic morph.
TheAnimaGemini ( ) posted Fri, 16 December 2011 at 11:12 AM
Quote - Wow!
I feel your pain...we have a chain necklace set for V4 and want to update it for Antonia, but hell, pain in the neck...
― Marcus Aurelius,
Cage ( ) posted Fri, 16 December 2011 at 11:43 AM
Quote - Cage, it's just that you're one of the brightest minds I know. Seriously! And for those of us less gifted, this process might need a gui to accomplish. I'm learning - laboriously - to write GUIs. What do you reckon? Worth the effort?
All of the TDMT scripts have GUIs already.  But you need to know where to place the files (the folder paths in the files on the site use an outdated version of Antonia and should be updated, but I need to find a new gtml editor before I can update my sites) and you need to know what buttons to push and when.  My efforts to provide instructions for the process haven't worked out so well.  :unsure:  What these (and many other of my scripts) need isn't a user interface, but documentation.  Whatever my skill set is, it still hasn't been able to grow to encompass writing decent documentation.  :lol:  😊
I don't want to derail the Antonia-WM thread with discussion about TDMT, though.  :scared:
Faery_Light ( ) posted Fri, 16 December 2011 at 12:02 PM
That Athletic morph looks great!
3doutlaw ( ) posted Fri, 16 December 2011 at 12:57 PM · edited Fri, 16 December 2011 at 12:57 PM
Yea, sorry to change topics to TDMT.  Cage, I posted over here a reply, if you got a minute?  http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2795602&page=20#message_3872180
That way I won't change topic here anymore.
Male_M3dia ( ) posted Fri, 16 December 2011 at 1:19 PM
Quote - Athletic morph.
Maybe the head size is too small, but something is odd about that body shape. Perhaps the muscles need to be more refined.
Glitterati3D ( ) posted Fri, 16 December 2011 at 1:26 PM
Quote - > Quote - Athletic morph.
Oh good!  Maybe that means you'll create some, right?
DCArt ( ) posted Fri, 16 December 2011 at 2:40 PM
What's up with the shape of her left thigh? Is that part of the morph, or part of the rigging?
Faery_Light ( ) posted Fri, 16 December 2011 at 2:45 PM
I never really noticed about the head looking too small.
It seems normal to me.
I watch wrestling sometimes and the way the wrestlers beef up, their heads always seem tiny compared to the body...lol.
Cage ( ) posted Fri, 16 December 2011 at 2:52 PM
Quote - I never really noticed about the head looking too small.
That can always be easily fixed, on Antonia.  The head scaling works nicely, and there is a special dial for handling head scaling.
A_ ( ) posted Fri, 16 December 2011 at 4:02 PM
*poking in
this is a pose i made (character+texture also by me), though this is the standard version and not the weight-mapped. looks really nice - look at the shoulders and the thighs - no awekwardness or anything. if you go to the product page of this character at RDNA, you'll see some more poses i made (don't want to flood this thread with promotional links..)
i'm working on more poses for her, hopefully i'll have time and can finish it quickly enough. i still need to further explore the differences between the standard bersion and the WM though. :)
LaurieA ( ) posted Fri, 16 December 2011 at 4:03 PM
She really does look lovely A_ :)
A_ ( ) posted Fri, 16 December 2011 at 4:07 PM
by the way, i completely ignored the whole earlier argument. :) i just wanted to share this pose. :)
Glitterati3D ( ) posted Fri, 16 December 2011 at 4:15 PM
Quote - > Quote - by the way, i completely ignored the whole earlier argument. :) i just wanted to share this pose. :)
Probably a very wise decision ;). I don't see at all why we can't have as many figures as we want. I'd use BH's girl for some things and happily use Antonia for others. No reason we can't. But to start bashing someone's product because some OTHER person unrelated to the product simply mentions it is the height of rude. There was no reason for that other than to be nasty.
No, Laurie, the reason for it was because I was asked my opinion.  Now, I understand you didn't care for my opinion, but I gave it only because I was asked.
I don't care for the product.  I would have happily ignored it forever.
StaceyG ( ) posted Fri, 16 December 2011 at 4:38 PM · edited Fri, 16 December 2011 at 6:56 PM
I had originally locked this thread due to the negative turn it had taken. After consideration I have decided to just remove all the posts that were off topic of the original post and let this thread continue on.
Please remember to be considerate of other opinions and have a positive discussion regarding the thread topic. I would appreciate if the discussion moves forward at this point and move past the negative discussion so please don't post about why any posts were removed in this thread but instead sitemail me if you have questions/concerns.
Thank you for your cooperation
RobynsVeil ( ) posted Fri, 16 December 2011 at 7:11 PM
Thank you, Stacy. 😄
Metaphor of Chooks
StaceyG ( ) posted Fri, 16 December 2011 at 7:22 PM
You are very welcome. I think this thread is important but I just want it to stay positive so hopefully it can.
Have a great weekend!!
Rose2000 ( ) posted Fri, 16 December 2011 at 7:46 PM
Yay.. Thank you!!! we are so Happy to have our thread back .. Thanks again :)
Glitterati3D ( ) posted Fri, 16 December 2011 at 7:59 PM
Quote - *poking in
She is beautiful!  I love the freckles.
She's on my wish list until the holidays are over.
RobynsVeil ( ) posted Fri, 16 December 2011 at 8:18 PM
Wow, A_ - those morphs are stunning!
Morphs that you create will work equally well in Standard and WM version. With WM, you have the advantage of, well, weightmapping (i.e, better bending and incredible clothing fits) and the optional sss-type shader that comes with her.
Metaphor of Chooks
meatSim ( ) posted Fri, 16 December 2011 at 8:24 PM
Freckles?!... Interest peaked!
I love freckles.. I'll have to add this to my want list!
Quote - > Quote - *poking in
alexcoppo ( ) posted Fri, 16 December 2011 at 9:06 PM
Somebody commented that Antonia is ugly. I myself don't like at all the default face, even though the inspiration (Nicola Roberts) is a beautiful redhead.
Using Afrodite-Okhi morphs, I managed to create a very faint resemblance of a renowned Bollywood actress (Kareena Kapoor). Resemblance... well, with an appropriate texture the two might look as if they came from the same planet but the message is that, even only with dial spinning, you can morph Antonia in sharply different characters (and all of them being "faries" :sneaky:).
B.t.w. if anybody is interested in the FC2, please let me know so that I might contribute it for the 21st Dec Antonia festival.
GIMP 2.7.4, Inkscape 0.48, Genetica 3.6 Basic, FilterForge 3 Professional, Blender 2.61, SketchUp 8, PoserPro 2012, Vue 10 Infinite, World Machine 2.3, GeoControl 2
Faery_Light ( ) posted Fri, 16 December 2011 at 9:19 PM
If one is patient the morphs can create different characters that does not look like fairies.
Here is one I'm working on and this is strictly using the Advanced morphs for APG.
RobynsVeil ( ) posted Fri, 16 December 2011 at 9:28 PM · edited Fri, 16 December 2011 at 9:28 PM
True, Antonia's default face is a bit... distinctive, but she seems to scrub up pretty well, in the right hands. I've seen renders where judicious hair-style and makeup makes her look quite pretty! (paging Amethyst: skilled artist that you are! 😄)
Metaphor of Chooks
Eric Walters ( ) posted Fri, 16 December 2011 at 9:50 PM
 Now that we are seeing Antonia with morphs that make her more traditionally "cute" or "pretty" I think we will see a broader interest. Most want to render people who look better than themselves (I do!). Looking good folks!
Eric Walters ( ) posted Fri, 16 December 2011 at 9:54 PM · edited Fri, 16 December 2011 at 9:59 PM
 Looks like a Boticelli paining. The Birth of Venus or Venus on the half shell!
If it is not an intentional resemblance, it must be subconscious! Creat a Giant Clamshell and you are most of the way to the first Boticelli Poser character
Quote - *poking in
RobynsVeil ( ) posted Fri, 16 December 2011 at 10:17 PM
Quote -  Now that we are seeing Antonia with morphs that make her more traditionally "cute" or "pretty" I think we will see a broader interest. Most want to render people who look better than themselves (I do!). Looking good folks!
Sweetie, Antonia in her default state looked better than I do. 😄 Seriously. I'd be delighted to look that good. :lol:
And then, there's my avatar - that's just my soul, there. Good job it isn't too reprehensible... :biggrin:
Metaphor of Chooks
meatSim ( ) posted Fri, 16 December 2011 at 10:19 PM
In truth I'm more likely to use Antonia's default face than I was ever likely to use v4s.  I have not oncedone a render I considered 'complete' with v4s default face.  Antonia I have done several.  She has her own look, but its definitly usable.  What I'd really like to see is a more in depth expression system (or pose pack.. I'm ok with being lazy :P )
Quote - True, Antonia's default face is a bit... distinctive, but she seems to scrub up pretty well, in the right hands. I've seen renders where judicious hair-style and makeup makes her look quite pretty! (paging Amethyst: skilled artist that you are! 😄)
RobynsVeil ( ) posted Fri, 16 December 2011 at 10:41 PM
Heck yeah, Lazy is my middle name, particularly when it comes to hands. We so need Ilona's touch here...
Metaphor of Chooks
TheAnimaGemini ( ) posted Sat, 17 December 2011 at 12:34 AM
Anat, she is lovely. :)
Poses and expessions, this is what we need for her badly. I am to lazy for poses, so I hopefingers cross Anat do some.
Expressions, I am worst with this. My characters look silly each time I put my hand on some expressions.
― Marcus Aurelius,
A_ ( ) posted Sat, 17 December 2011 at 6:11 AM
glad you like her, guys!
and i've always been unintentionally inspired by the classic masters, so that would explain why she looks like that. ;)
and - yes, i'm doing poses. so we'll see, maybe i'll release some hand poses too. so many things to do, so little time! :)
TheAnimaGemini ( ) posted Sat, 17 December 2011 at 6:41 AM
I just render your Poppy :) Yes, she is a beuty. As soon I have the render finish, I will upload the Image in my Gallerie.
Old Masters are our Inspirations too . I am a big fan from Waterhouse, Raphaelo , Michelangelo and Sir Lawrence Alma-Tadema. Pure beauty they created in their artworks.
― Marcus Aurelius,
LaurieA ( ) posted Sat, 17 December 2011 at 8:46 AM
I see a scene I want to do in every Waterhouse painting...lolol.
Afrodite-Ohki ( ) posted Sat, 17 December 2011 at 9:31 AM
Waterhouse <3 loooooooooooove~~
Feel free to call me Ohki!
TheAnimaGemini ( ) posted Sat, 17 December 2011 at 11:43 AM
laurie :blink:  LOL
Afrodite Oki, yes, he is my fav one. I love all his paintings :wub:
― Marcus Aurelius,
Cage ( ) posted Sat, 17 December 2011 at 2:52 PM · edited Sat, 17 December 2011 at 2:53 PM
I like Antonia in the classical mode.  :laugh:
A_ ( ) posted Sat, 17 December 2011 at 3:35 PM
that is lovely! :)
