Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 07 8:53 pm)
If you have an older version you can use this script http://www.renderosity.com/mod/freestuff/details.php?item_id=50718
I should have mentioned this the first time.
I have the same problem when using "leg length". I'm going to give the suggestions above a try in PP2012. It would be nice to fix that problem when the leg length is changed.
Poser Pro 2012 SR3
Windows 7 Professional 64 bit
Intel Core I7 990x 3.46G 6 core
24G RAM
EVGA GTX580 R Video Card
Single HP LP2475 1920x1200 monitor
______________________________
Edit: I had leg length set to 0.7
Poser Pro 2012 SR3
24G RAM
I'm a relative newbie, but having problems keeping v4 shoes to stay conformed with changes in the main character pose. I use v4 with all the extra morphs. I tend to use the leg length morph, to the maximum.
After each change in character pose, I usually have to select each shoe and adjust scaling on the thigh or shin to get the shoe to approximately accurate position (vertically). This problem occurs with almost all shoes from different vendors.
This is very time consuming to do all the time. Is there a better solution?
