Fri, Jan 10, 11:15 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Jan 10 10:00 pm)
Subject: Poser 2012 Pro is scrambling verticies in saved file? Never had this problem bef
chris1972 ( ) posted Fri, 30 December 2011 at 6:51 AM · edited Fri, 10 January 2025 at 11:15 PM
I purchased 2012 Pro a couple months ago and have been working on producing some new clothing items for V4. I have found that if I save the Poser file with the clothing items and then reopen the file  the verticies of the clothing items are scrambled. Theres nothing wrong with the obj, if I reimport the clothing item from its original file, its just fine. Ive experienced scrambled verticies before with morph targets that Poser didnt like, but that happens immediately upon import.
This new issue only occurs after the file has been saved.
Any ideas?
Photopium ( ) posted Fri, 30 December 2011 at 8:15 AM
have you tried zeroing the joints with the joint editor?  Sounds like maybe joints and IK to me on some unfinished WIPS.
Can you post a screenshot?
JimTS ( ) posted Fri, 30 December 2011 at 8:51 AM
Have you installed Sr 1?
A word is not the same with one writer as with another. One tears it from his guts. The other pulls it out of his overcoat pocket
Charles Péguy
 Heat and animosity, contest and conflict, may sharpen the wits, although they rarely do;they never strengthen the understanding, clear the perspicacity, guide the judgment, or improve the heart
Walter Savage Landor
So is that TTFN or TANSTAAFL?
chris1972 ( ) posted Fri, 30 December 2011 at 8:55 AM
What is Sr 1?
WandW ( ) posted Fri, 30 December 2011 at 11:27 AM
hborre ( ) posted Fri, 30 December 2011 at 11:29 AM
New Service Release 1.
chris1972 ( ) posted Fri, 30 December 2011 at 11:35 AM
Ok thanks, I'll check it out
ToxicWolf ( ) posted Fri, 30 December 2011 at 11:58 AM
Chris
I was having some problems like that.  I even had clothing end up as a lump on the figure head when I opened a previously save PZ3 file.  What solved the problem for me was to go into "General Preferences" and UNcheck the "use external binary morph targets", (if it is checked). This may not help, but it is a thought.
Poser Pro 2012 SR3
Windows 7 Professional 64 bit
Intel Core I7 990x 3.46G 6 core
24G RAM
EVGA GTX580 R Video Card
Single HP LP2475 1920x1200 monitor
______________________________
http://www.toxicwolf.com
Michael314 ( ) posted Sat, 31 December 2011 at 5:53 AM
Hello,
I did not have this issue, but the mentioned problems with "corrupt PMDs" occur frequently when I save a figure (complete, including conformers) from a scene into the library. This is with PoserPro 2012 before SR1 as well as with SR1. I didn't have the problem with PoserPro 2010.
Best regards,
    Michael
featherwitch ( ) posted Sat, 31 December 2011 at 7:51 AM
I've had that problem with dynamic clothing only, so far. Sometimes I have to delete the offending cloth, reload it and run the sim again, and then re-save the file and then it opens fine. Some glitch I presume. I don't use the save PMD, so... ??
wimvdb ( ) posted Sat, 31 December 2011 at 8:13 AM
Quote - I've had that problem with dynamic clothing only, so far. Sometimes I have to delete the offending cloth, reload it and run the sim again, and then re-save the file and then it opens fine. Some glitch I presume. I don't use the save PMD, so... ??
If this happens with dynamic cloth - just reset the simulation and re-run it.
If you have a clue what triggers this - please let me know. For me it always happens when I load another scene - but only occasionally
Regarding PMD's. There were a number of issues solved with SR1 with PMDs. If there are still some left SM likes to know how and when so they can solve it. I am using the PMDs all the time without problem and I have had many issues with it in PP2012 and previous versions - they all seem to be gone now
But that may not explain the issue from the OP
rjjack ( ) posted Sat, 31 December 2011 at 8:16 AM
next time you have this try to clear the simulation and run it again, maybe you don't need to delete the cloth.
featherwitch ( ) posted Sat, 31 December 2011 at 8:30 AM
Thanks all!  :o) I've probably tried it that way, but didn't pay attention to the results. I've got SR1 now so will try to pay more attention and see what happens- if it happens again. ;o)
Happy New Year to you and yours!
