Wed, Feb 19, 5:32 PM CST
Subject: Editing an Animation way point
surveyman ( ) posted Wed, 04 January 2012 at 2:51 AM · edited Wed, 19 February 2025 at 5:17 PM
I'm just learning animation.  I'm getting it, but am having a problem changing the position "Z" (elevation) value of the animation path spline (blue line).
Every time I try to lower/raise the elevation of the way point, it snaps back to its original location as soon as I finish the movement.  The "X" and "Y" spline positions (red & green) I can change/move without a problem.
The animation Wizard does not let you alter the elevation of the vertical spline path,. nor does it let you key in numerical elevation values.
I'm using xStream 10, but I found the same problem in xStream 9.5.
Tx.
bruno021 ( ) posted Wed, 04 January 2012 at 3:10 AM
Why don't you do this in the viewport?
ShawnDriscoll ( ) posted Wed, 04 January 2012 at 3:25 AM
Is your camera's height locked or unlocked?  Kept level, or no?
surveyman ( ) posted Wed, 04 January 2012 at 2:36 PM
Thanks Shawn - the camera was 'locked' - I guess that is the default setting.  As soon as I unlocked it, I could move the waypoints in three dimensions.
Bruno - when the camera is 'locked', the waypoints in the 3D views are locked in their vertical positions as well.  Thanks though.
bruno021 ( ) posted Wed, 04 January 2012 at 3:57 PM
Not if you're not going below the locked altitude... Actually, right now in Vue 10, you can even go under any locked altitude. Guess it's a bug!
surveyman ( ) posted Wed, 04 January 2012 at 4:25 PM
Bruno,
The altitude was not locked, the camera was.  However, I do not understand why with a locked camera I could alter the waypoint X & Y data but not the Z.  All I did was click on the camera 'lock' to unlock it and then it behaved like I expected it to.
ShawnDriscoll ( ) posted Wed, 04 January 2012 at 6:01 PM
surveyman,
Just be careful "when" you unlock the camera.  It's best to do it before even beginning a timeline.  Vue will gladly assist you with unlocking a camera if you are in the middle of a timeline, for instance, which will cause headaches.  The entire camera workflow in Vue is a kludge, so it's hard to spot a bug while using one.
surveyman ( ) posted Thu, 05 January 2012 at 2:51 PM
LoL.  At this point, I'm not sure what is a 'bug' and what is 'designed bahavior'.  I'm just playing around, trying things and seeing what happens.  I did notice that I had to tweak the camera path a few times because 'things changed' on me.
I built a new computer for doing animations (i7-3930 w/ 32Gb ram & SSD) and it's still a 'bear' to render.  90 second animation @ 640x400 took 12+hrs to render.  Just a simple island w/ tropical eco.  But the time to render the same scene on my old Q6600 was estimated at 72+hrs. LoL.
Wish there were instructions on how to streamline the rendering options for best/fastest animation output.  I did notice that the new anti-flickering process adds about 45% to the render time, but really cuts down on the flickering.  Ran 2 animations & compared.
Tx for the warning - I'll keep an eye out for those 'features'.
