Poser - OFFICIAL F.A.Q (Last Updated: 2024 Oct 02 9:25 am)
You should be able to protect some elements like the hair with a mask in photoshop.
"Dream like you'll live forever. Live like you'll die tomorrow."
Attached Link: http://www.renderosity.com/mod/gallery/index.php?image_id=2262534&user_id=29771&np&np
Have you tried with a light plane infront of her for the highlights? I've had some pretty good results with that."Dream like you'll live forever. Live like you'll die tomorrow."
I'll join you, Laurie - even with that brain cell of yours I've confiscated, I still feel... um, what was the word you used again.... ??? :-/
Why aren't these images ever on Staff Picks? or Carodan's? You guys set a new (pretty-much unattainable to the unwashed masses) standard for us. Have you considered doing a tutorial, Richardson? or two? or five?
This is simply mindboggling...
Quote - I noticed this for years really. Once you convert a render to greyscale, you see how little contrast survives at rendertime.
Just a thought...have you tried going into the channels and clicking on each of the color plates...r, g, and b? sometimes one of those has more detail or the detail you want than just converting to greyscale :). If you chose one of the channels and delete the other two you may be able to keep more of the details. It's been been my experience that red or blue usually seem to get the closest to what I'm after ;). Then convert that one color to greyscale :). Or you could copy each one, desaturate and then layer them using different layer settings...see what ya get.
Quote - ...
I noticed this for years really. Once you convert a render to greyscale, you see how little contrast survives at rendertime. I'm sure there is an explanation.
Anyway, I zipped the scene up with the Zbrushed object if anyone wants a go at it. Send me a sm to email to.
I would go at this from a photographers POV...
Render to HDR... this should give you much more data to play with...
(like shooting in RAW vs. JPG)
Then take it into Photoshop...
Here's a nice, short article about creating b/w images in Photoshop...
http://photo.net/learn/digital-photography-workflow/advanced-photoshop-tutorials/converting-to-black-and-white/
Martin
Yesterday's the past, tomorrow's the future, but today is a gift. That's why it's called the present.
Hmm.. I did'nt get that kind of results when I played with it.
Nice work.
There is no universal "physics says" way to convert color to grayscale.
But if you're trying to match a camera, you can't do it by simply averaging R, G, B which is usually what people do.
You might want to try my Artistic Lens, which lets you render B&W directly in Poser, no Photoshop or other postwork.
Anyway the equation that is identical to B&W television involves a weighted sum, which I included in the Artistic Lens.
Artistic Lens Thread:
http://www.renderosity.com/mod/forumpro/showthread.php?thread_id=2754029
Note: I suspect my artistic lens shader won't work with GC on.
I probably used a color to do the weighted sum.
It would have to be adjusted for modern Poser use.
Let me know if you need it.
Outstanding work richarson.
What makes her pop is the wall is darker than the wall you have in the render. This is by looking at your render and the image side-by-side
"Cheat" and make the diffuse of the concrete wall/floor a bit darker than you alerady have it and see what happens.
Also given the model (the Poser model not the Model model) has got that shoulder thing happening. The Model model's back seems to catch more light.(Got how I want to phrase this) The dropoff from the Poser models back to the shoulder is more pronounced/sharper than the dropoff from the Model model's back to shoulder, so Model model gets more light (thus spec) on her back than Poser model does. Got a shoulder fix morph for the Poser model?
(Does that make sense?)
Intel Core i7 920, 24GB RAM, GeForce GTX 1050 4GB video, 6TB HDD
space
Yep. More time in Zbrush is what you are saying. Shoulder "fixes" don't work. Not on a non default figure. I can pull that into position in ZB much better. Might as well start from scratch though and use precise measurements. This was eyeballed in a few hours. Maybe tomorrow. I can see lots of position problems.
"@bh,
I think you got it. "
ive seen great results with gamma correction on in certain renders, but i have yet to see someone get deep, dramatic shadows or inky blacks with it enabled.
one of the first things many photographers do after snapping photos is take them into PS/LR and adjust levels. GC is great but it doesnt have to be on for every render.
Yes, it was fun... and even more so, because it isn't easy... :-)
Somehow this exercise reminded me of one of the first images I created back in 2003...
That render was based on a photo as well...
http://www.renderosity.com/mod/gallery/index.php?image_id=599474
Almost looks like I haven't learned much in those 8 years :lol:
Kinda screwed the displacement map and then deleted the object. I'm NOT doing it again. My first dynamic hair trial in years and some post corrections to fix a bald spot. If I had a month,,, it would be much better. Overall happy with PPro2012 and the nodework of others that I could reach from. Thanks
Attached Link: http://www.google.com/imgres?q=B%26W+nude+photography+Igor+Igor&hl=en&safe=off&biw=1600&bih=1017&tbm=isch&tbnid=OZVIE9UsnOk5QM:&imgrefurl=http://www.obsessionart.com/product-Igor-Amelkovich-Close-to-Wall-02-IGOR_IGOR016.htm&docid=zZk6xaoZI3h_PM&imgurl=htt
Hey,I was trying to match this photo by Igor Amelkovich as a challenge (link). started to get some results and then sort of plateau'd. What stood out was my inability to get the high specular and shading/shadowing at the level of the photo.
Below, my best so far. IDL, SSS, one light, one light box and bb's envirosphere. Body is at sub1 so, not much detail yet. I used V4Hi, snarly's EZskin with fresnel, and a concrete texture.
