Wed, Nov 13, 9:22 AM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 12 11:30 pm)
Subject: Backgrounds
vitachick ( ) posted Thu, 29 December 2011 at 3:35 AM · edited Mon, 11 November 2024 at 8:35 AM
Kinda new to Poser2010. I see where you can import background, but for the life of me I cannot see where to delete it.  Checked the manuel showed ctrl B but that did not delete it just make it invisible. I rendered the scene again and it was back. Also seems as though the background never fits the window. Dumb question??
Win10  Poser 2014/Poser 11 Daz3D
RobynsVeil ( ) posted Thu, 29 December 2011 at 3:47 AM · edited Thu, 29 December 2011 at 3:48 AM
Good on you for checking the manual - lots of people don't. So, this is good.
When you hit [ctrl] [y] you'll get render settings... on the right-hand side, you'll see, under Options: Render over. Might want to check out that dropdown.
Thing is: that background picture option really isn't the best. I generally use a panorama object and display a picture on this, like in this image:
Seaside
The water is a procedure (shader) on the ground surface - the sky is a picture of a sky on a panorama object.
Metaphor of Chooks
PhilC ( ) posted Thu, 29 December 2011 at 4:07 AM
Its only dumb if you don't ask the question but continue to struggle :)
Go to the Material Room.
In the Object drop down list select "Background"
Select the "BG Picture" node and either delete it or disconnect it from the Background.
Hope that helps.
vitachick ( ) posted Thu, 29 December 2011 at 7:55 AM
Thanks alot for your quick replies :)
vitachick ( ) posted Mon, 09 January 2012 at 5:00 AM · edited Mon, 09 January 2012 at 5:02 AM
Back again. Poser2012...Render window is 873 x 844.  Background image is 2600 x 3800... Per attached you can see what happens.  It does not fill up the whole screen.
Daz3 np... Have no clue unless you  cannot use purchased backgrounds in Poser
vitachick ( ) posted Mon, 09 January 2012 at 5:43 AM
RobynsVeil ( ) posted Mon, 09 January 2012 at 5:44 AM · edited Mon, 09 January 2012 at 5:45 AM
Quote - Back again. Poser2012...Render window is 873 x 844.  Background image is 2600 x 3800... Per attached you can see what happens.  It does not fill up the whole screen.
Your camera focal length... 25? so, wide-angle?
You're best off getting some panorama obj or other plane (cloth_plane in Poser primitives in your props library) to display that image against - you would do this in the material room with a ImageMap node. Then, you can adjust the size (scale) of the plane and also of your camera focal length and have better control over the background image.
Metaphor of Chooks
vitachick ( ) posted Mon, 09 January 2012 at 6:06 AM
Ah tried opening primitive but had trouble trying to find where to apply image map...Only color...Will keep working on it..
Thanks
RobynsVeil ( ) posted Tue, 10 January 2012 at 3:06 AM
You can apply the imagemap in two places in the PoserSurface node: Diffuse_Color and Alternate_Diffuse.
From the output plug on the ImageMap node, just drag a connection to the input for the Diffuse_Color channel - you'll see the little plugs.
Metaphor of Chooks
RobynsVeil ( ) posted Tue, 10 January 2012 at 3:08 AM
And plug in...
Metaphor of Chooks
vitachick ( ) posted Tue, 10 January 2012 at 5:33 AM
Thank you for reply.  I found a wall_plane and applied the back image to that. It worked. Poser2012 is so intimating.. All those settings etc and not knowing what they do except by experiment.  Don't know how long it took everything here to learn everything but I still am in awe... Someone has a question and zap the answer is posted....Right now I'm in Poser kindergarten. Hope to advance to first grade soon LOL
hborre ( ) posted Tue, 10 January 2012 at 11:42 AM
If you use a plane to display your background, use the trechnique Robyn outlined and set your scale x and y according to your pixel resolution of the image, then perform the overall scale.  For example, if your image is 2600x3800, set x scale = 2600 and y scale = 3800.  Rescale your prop until it fits you scene.
vitachick ( ) posted Tue, 10 January 2012 at 12:15 PM
Ok..thanks once again!!
RobynsVeil ( ) posted Tue, 10 January 2012 at 3:32 PM
Quote - If you use a plane to display your background, use the trechnique Robyn outlined and set your scale x and y according to your pixel resolution of the image, then perform the overall scale.  For example, if your image is 2600x3800, set x scale = 2600 and y scale = 3800.  Rescale your prop until it fits you scene.
Wow, thanks, HBorre! Honestly, I didn't know that one either!
Metaphor of Chooks
hborre ( ) posted Tue, 10 January 2012 at 6:38 PM
Yes, that avoids distorting the image yet maintains resolution when doing overall final scaling.
shannonsuzanne ( ) posted Sat, 28 January 2012 at 8:27 AM
All very useful.  Glad someone pointed me to this one.
