Mon, Feb 10, 3:17 AM CST
Subject: Weird problem! Help please!
meltz ( ) posted Wed, 11 January 2012 at 9:47 AM · edited Mon, 10 February 2025 at 3:04 AM
Ok im using poser pro 2012. I have tried two different scenes and keep having the same problem. I have highlighted the problem in the attachments in yellow. For some reason when i render the wall/window bloons and expands for an odd reason. This only shows up when i render and not in the preview while im designing the scene.  Any clue? I have tried to deleate key frames but that didnt work. Also have tried to created a whole new scene and still it happens.   Could it be from one of the two characters that i import into the scenes?
Thanks for any help as this is driving me nutz the last two days =-(
second scene!
Winterclaw ( ) posted Wed, 11 January 2012 at 9:50 AM
Hard to tell with the lighting.  Try turning smoothing off and see if it goes away.  It might not have been made with poser smoothing in mind.
WARK!
Thus Spoketh Winterclaw: a blog about a Winterclaw who speaks from time to time.
(using Poser Pro 2014 SR3, on 64 bit Win 7, poser units are inches.)
Khai-J-Bach ( ) posted Wed, 11 January 2012 at 9:50 AM
goto the wall Mesh and turn off Smoothing for it...?
meltz ( ) posted Wed, 11 January 2012 at 9:54 AM
ill give it a try as soon as i get back home. hope thats what is wrong!
hborre ( ) posted Wed, 11 January 2012 at 10:03 AM
To elaboarte on the 2 replies: either turn off smoothing on the render settings which will affect everything globally, or go to the parameter/properties palette of the object and turn off smoothing under the properties tab.  This will only affect the particular object in question and not the overall scene.
If you are adept at working with mesh, you can repair it in a 3rd party program.
meltz ( ) posted Wed, 11 January 2012 at 10:30 AM
THANKS Hborre. I just found it weird that it happend in two different scenes when this has never happend to me ever. Ill try turning it off as soon as i get back into poser =-)
meltz ( ) posted Wed, 11 January 2012 at 6:39 PM
Yup that smoothing off did the trick! Thanks so much guys, this is the best forum for help!
markschum ( ) posted Wed, 11 January 2012 at 9:40 PM
this is a known problem with Poser smoothing and can be fixed in a modelling program.
You may be able to fix it by trying different crease angles rather than turning smoothing off for the item.
SamTherapy ( ) posted Thu, 12 January 2012 at 5:00 AM · edited Thu, 12 January 2012 at 5:01 AM
There's some serious poke through on the sleeping woman's clothes, too.
