Thu, Feb 13, 12:20 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2025 Feb 13 7:03 am)
Subject: Poser 8 - How do I turn off Sub Surface scattering?
Michaelab ( ) posted Thu, 12 January 2012 at 1:09 PM · edited Thu, 13 February 2025 at 12:10 PM
I have Poser 8.
I went into the material room and turned on sub surface scattering for the face, head, hands, etc, of my Michael 4 character. As my test renders are taking a horrifically long time, I'm wanting to turn this SSS off, but don't see an option to do so, hoping this will cut down the test render time.
Is there a way to turn off the SSS that I turned on?
wimvdb ( ) posted Thu, 12 January 2012 at 1:32 PM
Yes, Poser 8 does not have sub surface scattering.....
hborre ( ) posted Thu, 12 January 2012 at 1:38 PM
Online Now!
You will need to disconnect those nodes from the PoserSurface in the material room.  However, as wimvdb mentioned, there is no real SSS in P8.  In P9/PP2012, SSS can be controlled through the render settings.
MistyLaraCarrara ( ) posted Thu, 12 January 2012 at 2:06 PM
can you reapply the original texture set you had for M4?
to do it manually, you'd need to unplug the fastscatter node in all his material zones.
Michaelab ( ) posted Thu, 12 January 2012 at 2:19 PM
Could you tell me which nodes to disconnect? There are over a dozen.
Michaelab ( ) posted Thu, 12 January 2012 at 2:24 PM
Ok, I deleted the two fastscatter nodes I saw. Is there anything else I need to do?
MistyLaraCarrara ( ) posted Fri, 13 January 2012 at 10:45 AM
can you post a screen shot of your material room?
