The hip issue is becaue IK is turned off in the legs, so turn it back on.
I'm too lazy to check right now, but I believe that v4 and M4 normally have the translation dials hidden for most body parts...
"Oh - the manual says that? I have never read the manual - this must be why."Glad I could help...
"Oh - the manual says that? I have never read the manual - this must be why."This site uses cookies to deliver the best experience. Our own cookies make user accounts and other features possible. Third-party cookies are used to display relevant ads and to analyze how Renderosity is used. By using our site, you acknowledge that you have read and understood our Terms of Service, including our Cookie Policy and our Privacy Policy.
Hello guys and gals,
I've got a weird problem here, let me explain to you what i have figured up until now:
I made a full body morph for M4 on another 3d program, then went to poser and through the menu Figure -> Load Full Body morph i loaded the Obj file, no problem, everything was OK.
I started working on textures, nodes, SSS and stuff, saved a couple of versions and closed poser, opened it again with the same scene and continued working on it, then i wanted to try something diiferrent and decided to create a new scene, which i did, and when i loaded M4 on this new scene the problems arised, the X, Y and Z dials from the Translation for the feet were missing, the hip had lost a the ability to make the lower limbs bend when dialing the Y dial, now it moves the whole body through the floor instead, i mean move it with the body stiff like a nail, the X and Z dials behave on the same way.
The scene that i had saved previously behave normally,but, if i insert a new M4 on the scene however it i will have the same problems describe above and so does V4.
what could be happening?any idea on how could i solve it?
thank you all in advance
