Mon, Nov 25, 10:25 PM CST
Poser - OFFICIAL F.A.Q (Last Updated: 2024 Nov 25 12:38 pm)
Subject: M4 and V4 missing translation dials
brdarkmoon ( ) posted Sat, 14 January 2012 at 5:13 PM · edited Sat, 17 August 2024 at 2:36 AM
Hello guys and gals,
I've got a weird problem here, let me explain to you what i have figured up until now:
I made a full body morph for M4 on another 3d program, then went to poser and through the menu Figure -> Load Full Body morph i loaded the Obj file, no problem, everything was OK.
I started working on textures, nodes, SSS and stuff, saved a couple of versions and closed poser, opened it again with the same scene and continued working on it, then i wanted to try something diiferrent and decided to create a new scene, which i did, and when i loaded M4 on this new scene the problems arised, the X, Y and Z dials from the Translation for the feet were missing, the hip had lost a the ability to make the lower limbs bend when dialing the Y dial, now it moves the whole body through the floor instead, i mean move it with the body stiff like a nail, the X and Z dials behave on the same way.
The scene that i had saved previously behave normally,but, if i insert a new M4 on the scene however it i will have the same problems describe above and so does V4.
what could be happening?any idea on how could i solve it?
thank you all in advance
WandW ( ) posted Sat, 14 January 2012 at 5:19 PM · edited Sat, 14 January 2012 at 5:20 PM
The hip issue is becaue IK is turned off in the legs, so turn it back on.
I'm too lazy to check right now, but I believe that v4 and M4 normally have the translation dials hidden for most  body parts...
brdarkmoon ( ) posted Sat, 14 January 2012 at 5:29 PM
Well...That now made me red in shame.
Thank you very much my friend, you solved both my problems, those dials are not hidden for the feet, however they were hidden for me and appeared as soon as i turned IK on for both legs.
Thank you very much again my friend
WandW ( ) posted Sat, 14 January 2012 at 6:18 PM
Glad I could help...  😄
