Sat, Jan 11, 6:20 AM CST
Subject: Poser 2012 Render Question
shorterbus ( ) posted Tue, 17 January 2012 at 1:10 PM · edited Sat, 11 January 2025 at 5:15 AM
I have a 64 bit pentium dual core CPU, ES 540 - 2.7 ghz. Windows 7
Looking for as much render speed as possible. Under the General Preferences/Render tab, at what do I set the number of threads?
Do I check "separate Process"?
Thanks.
willyb53 ( ) posted Tue, 17 January 2012 at 1:19 PM
The general recommendation is one thread per core, but if your cpu supports hyperthreading you may gain some speed with more threads.
Separate process will slow you down due to setup time on a 64 bit system.
The best way to test is create a test scene, render once to get everything in memory.
then use render firefly script with render(time) option and play
Bill
MistyLaraCarrara ( ) posted Tue, 17 January 2012 at 2:02 PM
you could send the render to Queue Manager or render in background, then you could keep on working while it's rendering  :idea:
shorterbus ( ) posted Tue, 17 January 2012 at 2:20 PM
Misty, how do I render in background?
MistyLaraCarrara ( ) posted Tue, 17 January 2012 at 2:30 PM
Open the Render Setting dialog when you're ready to start.
There is a little drop down list near the bottom of the dialog,
you'll see a few options,
one of them is the Render in Background.
ToxicWolf ( ) posted Tue, 17 January 2012 at 3:24 PM
Just so you know, I have my 6 core set to 12 threads and it works.  I will try some different settings to see if there is any improvement.  But for now, I am not having any problems with it.  Is your Windows 7 64bit or 32bit.
Poser Pro 2012 SR3
Windows 7 Professional 64 bit
Intel Core I7 990x 3.46G 6 core
24G RAM
EVGA GTX580 R Video Card
Single HP LP2475 1920x1200 monitor
______________________________
http://www.toxicwolf.com
vilters ( ) posted Tue, 17 January 2012 at 4:20 PM
Check separate process becomes faster when you are getting low on RAM under an OS that has a RAM limitation.
shorterbus ( ) posted Tue, 17 January 2012 at 5:33 PM
Windows 64 bit
MistyLaraCarrara ( ) posted Wed, 18 January 2012 at 11:21 AM · edited Wed, 18 January 2012 at 11:21 AM
here's a screenshot of Render in Background menu
it's in a couple of places
shorterbus ( ) posted Thu, 19 January 2012 at 9:48 AM
Thanks!
